Thread Tools
Display Modes
Denis in NJ |
Good read, but Newfound is listed in the article as the deepest lake in NH at 183 feet, Wiki lists Winnipesaukee at 212 feet. I wonder which is correct?
For years, the Green & White (The Duncan Fitchet) map of Lake Winnipesaukee listed the deepest point at 187 feet. Bizer, of course, lists it at 213 feet. I have personally scanned Winnipesaukee's deepest point at around 203 feet with a Humminbird scanner. All three of these readings obviously exceed the published depth of 183 feet in Newfound Lake.
Lake Winni - The only place I want to be during the summer. ![]() |
The Following User Says Thank You to Senter Cove Guy For This Useful Post: | ||
Y2K (05-09-2023) |
Newfound is supposedly the cleanest... and still has the small lake vibe that Winnipesaukee is losing.
ApS (05-05-2023) |
If I recall correctly, "Three Centuries on Winnipesaukee" relates 300' deep in Weirs Bay, suggesting that there is a hole of cantilevered ledges. Drop your lead line, jiggle over a few feet and it drops again. Rinse and repeat. Ledges and legends are in abundance around the lakes region. Maybe the Weirs hole is covered by debris from the Mount Washington, never to be found again ?
I.C.Isles (05-05-2023) |
#6 | |
Visit Thomson Lake in Maine. Reminds me of the lake back in the 50s.
I have seen it.
Newfound and Squam are now seeing owners that are willing to wait the six months for high end Signature Ultimate... even with the cost. The east side of Winnipesaukee and Squam were historically the higher priced millwork requests... but now it seems to be spreading out. They are looking for traditional units that are unique in design. |
#8 | |
I have measured what I believe to be the deepest point in the lake many times with my Garmin chartplotter. It has read from 201 to 204 consistently.
Along with info from the previous posts, I would be skeptical that 183' is deeper than Winni. I, too, enjoyed the article (except for that)! ![]() |
Newfound Lake's deepest spot of 183' is close enough to the West Side Rd granite cliffs that you can cast a fishing line while standing on the roadside rocky embankment into the deep water.
There's one small parking spot, close by. Directly behind the road and very close to the lake is a vertical granite cliff of maybe 200' height, or do. Similar to Lake Winnipesaukee, Newfound Lake was created by building a dam across the outflow water in the early 1800's.
#11 | |
The Following User Says Thank You to Bizer For This Useful Post: | ||
Y2K (05-09-2023) |
The Bizer chart reading of 213 is essentially correct. The location lies almost exactly on the course of the Mount Washington on her return from Wolfeboro to Weirs. I've driven over the spot several times in past years. The depth sounder shows a contour of a fairly smooth, deep bottom as one approaches the point, then a sharp dive into the hole, then a sharp rise coming out. I'm sure any other measurements would be welcome to check these results, so if you have a decent depth finder on your boat, try it.
This is a pretty cool resource, and a site where you can waste many hours.
https://webapp.navionics.com/?lang=e...y=ez~hGp%7BirL Ever notice how deep the Finger Lakes in upstate New York are? Crazy!
"When I die, please don't let my wife sell my dive gear for what I told her I paid for it." |
The Following User Says Thank You to Grant For This Useful Post: | ||
jbolty (05-11-2023) |
“ Similar to Lake Winnipesaukee, Newfound Lake was created by building a dam across the outflow water in the early 1800's.”
Not so. The lake was created thru erosion and then glacially and the water level remains close to the same as it was 50,000 years ago. The dam controls the flow of water out and the level of the lake (+/- a couple feet) but you’d still have the lake without the dam. |
At the southern end of Newfound Lake is the lake outflow, the Newfound River which is a fly-fishing only river plus it has a walking/bicycling trail that parallels the river as it flows down to Bristol, NH and into the Pemigewasset River. There's a concrete dam close to the start of the Newfound River and a second dam down closer to Bristol that can be seen from Route 3A.
The Newfound Lake Dam and the Lakeport Dam in Lakeport, Laconia are both controlled by the NH-DES and used to seasonally lower and raise the water levels on Newfound Lake and Lake Winnipesaukee. Without these two dams both Newfound Lake and Lake Winnipesaukee would still exist but at an unknown lower level.
Went camping to Crater Lake last summer…1,900’ deep! Incredibly clear water…you can see bottom at 100’!
#17 |
I've always wanted to dive Crater Lake for that very reason. I wonder if there are any groups that dive it regularly.
#19 |
Marvin Window product.
It allows for a lot of sizing and configuration options... but it takes a long time to get. The Newfound and Winnisquam projects, that I have gotten recently, seem to be smaller cottages that the owners want a lot of detail. |
#20 |
I know of four currently being built here on Winnisquam. And yes, they are of moderate size. And they each have outstanding views. Another property just went on the market. 950 sq feet and a bit over one acre for 2 million. Crazy number
