Old 05-05-2023, 01:13 PM   #1
Denis D
Default Interesting read re. our deepest lake
https://www.msn.com/en-us/weather/to...5335167&ei=143
Denis in NJ
Denis D is offline   Reply With Quote
Old 05-05-2023, 01:48 PM   #2
Good read, but Newfound is listed in the article as the deepest lake in NH at 183 feet, Wiki lists Winnipesaukee at 212 feet. I wonder which is correct?
Old 05-05-2023, 02:24 PM   #3
Senter Cove Guy
Senter Cove Guy's Avatar
Default Winnipesaukee Depth Scanning - Duncan, Bizer & Personal
For years, the Green & White (The Duncan Fitchet) map of Lake Winnipesaukee listed the deepest point at 187 feet. Bizer, of course, lists it at 213 feet. I have personally scanned Winnipesaukee's deepest point at around 203 feet with a Humminbird scanner. All three of these readings obviously exceed the published depth of 183 feet in Newfound Lake.
The Following User Says Thank You to Senter Cove Guy For This Useful Post:
Y2K (05-09-2023)
Old 05-05-2023, 02:40 PM   #4
John Mercier
Newfound is supposedly the cleanest... and still has the small lake vibe that Winnipesaukee is losing.
ApS (05-05-2023)
Old 05-05-2023, 04:19 PM   #5
If I recall correctly, "Three Centuries on Winnipesaukee" relates 300' deep in Weirs Bay, suggesting that there is a hole of cantilevered ledges. Drop your lead line, jiggle over a few feet and it drops again. Rinse and repeat. Ledges and legends are in abundance around the lakes region. Maybe the Weirs hole is covered by debris from the Mount Washington, never to be found again ?
I.C.Isles (05-05-2023)
Old 05-05-2023, 04:29 PM   #6
Default Agreed
I concur with this as well. I too have trolled over the deepest point on numerous occasions and my sonar readings duplicate yours at just over 200’…
Old 05-05-2023, 07:28 PM   #7
Cobalt 25
I have measured what I believe to be the deepest point in the lake many times with my Garmin chartplotter. It has read from 201 to 204 consistently.
Along with info from the previous posts, I would be skeptical that 183' is deeper than Winni.
I, too, enjoyed the article (except for that)!
Old 05-06-2023, 05:44 AM   #8
Newfound Lake's deepest spot of 183' is close enough to the West Side Rd granite cliffs that you can cast a fishing line while standing on the roadside rocky embankment into the deep water.
There's one small parking spot, close by.
Directly behind the road and very close to the lake is a vertical granite cliff of maybe 200' height, or do.
Similar to Lake Winnipesaukee, Newfound Lake was created by building a dam across the outflow water in the early 1800's.
Old 05-06-2023, 08:20 AM   #9
As Lake Winnipesaukee gets 'overdeveloped', people are looking at Winnisquam and Squam Lake. Real estate prices have skyrocketed on those two lakes.
Visit Thomson Lake in Maine. Reminds me of the lake back in the 50s.
Old 05-06-2023, 12:09 PM   #10
John Mercier
I have seen it.
Newfound and Squam are now seeing owners that are willing to wait the six months for high end Signature Ultimate... even with the cost.
The east side of Winnipesaukee and Squam were historically the higher priced millwork requests... but now it seems to be spreading out. They are looking for traditional units that are unique in design.
Old 05-06-2023, 01:39 PM   #11
Signature Ultimate?
Old 05-06-2023, 02:33 PM   #12
John Mercier
Marvin Window product.
It allows for a lot of sizing and configuration options... but it takes a long time to get.
The Newfound and Winnisquam projects, that I have gotten recently, seem to be smaller cottages that the owners want a lot of detail.
Old 05-06-2023, 02:43 PM   #13
I know of four currently being built here on Winnisquam. And yes, they are of moderate size. And they each have outstanding views. Another property just went on the market. 950 sq feet and a bit over one acre for 2 million. Crazy number
Old 05-09-2023, 09:06 AM   #14
Bizer
Bizer's Avatar
Bizer recorded a depth of 206 about 20 years ago. The "213" on Bizer's chart is based on input from Tom Wachsmuth at Dive Winnipesaukee in Wolfeboro.
The Following User Says Thank You to Bizer For This Useful Post:
Y2K (05-09-2023)
Old 05-09-2023, 03:09 PM   #15
skprbob
Default depth
The Bizer chart reading of 213 is essentially correct. The location lies almost exactly on the course of the Mount Washington on her return from Wolfeboro to Weirs. I've driven over the spot several times in past years. The depth sounder shows a contour of a fairly smooth, deep bottom as one approaches the point, then a sharp dive into the hole, then a sharp rise coming out. I'm sure any other measurements would be welcome to check these results, so if you have a decent depth finder on your boat, try it.
skprbob is offline   Reply With Quote
Old 05-10-2023, 11:10 AM   #16
Grant
Grant's Avatar
This is a pretty cool resource, and a site where you can waste many hours.
https://webapp.navionics.com/?lang=e...y=ez~hGp%7BirL
Ever notice how deep the Finger Lakes in upstate New York are? Crazy!
The Following User Says Thank You to Grant For This Useful Post:
jbolty (05-11-2023)
Old 05-12-2023, 03:19 AM   #17
Pricestavern
Pricestavern's Avatar
Default Lake Formation
“ Similar to Lake Winnipesaukee, Newfound Lake was created by building a dam across the outflow water in the early 1800's.”
Not so. The lake was created thru erosion and then glacially and the water level remains close to the same as it was 50,000 years ago. The dam controls the flow of water out and the level of the lake (+/- a couple feet) but you’d still have the lake without the dam.
Old 05-12-2023, 05:49 AM   #18
At the southern end of Newfound Lake is the lake outflow, the Newfound River which is a fly-fishing only river plus it has a walking/bicycling trail that parallels the river as it flows down to Bristol, NH and into the Pemigewasset River. There's a concrete dam close to the start of the Newfound River and a second dam down closer to Bristol that can be seen from Route 3A.
The Newfound Lake Dam and the Lakeport Dam in Lakeport, Laconia are both controlled by the NH-DES and used to seasonally lower and raise the water levels on Newfound Lake and Lake Winnipesaukee. Without these two dams both Newfound Lake and Lake Winnipesaukee would still exist but at an unknown lower level.
Old 05-12-2023, 10:32 AM   #19
dickiej
Went camping to Crater Lake last summer…1,900’ deep! Incredibly clear water…you can see bottom at 100’!
Old 05-12-2023, 10:59 AM   #20
Grant
Grant's Avatar
I've always wanted to dive Crater Lake for that very reason. I wonder if there are any groups that dive it regularly.
This page was generated in 0.10561 seconds
