Old 05-02-2021, 07:19 AM   #1
Cal-to-NH
Cal-to-NH's Avatar
Default Handyman /Carpenter recommendation - doorway water damage
Hi folks:
Got Carpenter ants like you read about at one of my doorways! Looks like I may have invisible water damage at that doorway. Does anyone have a handyman/carpenter that can pull the door jambs and trim-work to see where this water is getting-in?
Since home improvement work has skyrocketed I am hopeful that there are still some folks out there willing to do smaller jobs....
Cal-to-NH is offline   Reply With Quote
Old 05-30-2021, 08:35 AM   #2
Kneedeep
Hello if you are still looking for someone to help you on this please let me know.
Kneedeep is offline   Reply With Quote
Old 05-30-2021, 05:03 PM   #3
I have a similar issue with a storage shed in a condo complex where I own.
The building actually contains several storage units/closets that are all tied together structurally, but separated by individual doors. I own one of the units. Each unit/closet is about 4' by 8'.
I digress from the original topic..... the door frame/casing has 'water' damage/rot from the ground up about 3"-4", on each side of the frame.
Just a FYI, the door frame sits on concrete.
Thinking the most cost-effective, rather than ripping or cutting out the 'casing', that maybe that the repair can be made with a 'Bondo' type patching material ? I am nowhere near the condo (winter condo), and cannot repair myself, so most likely will have to hire someone to repair in my absence.
Thoughts about using 'Bondo' for fix ?
Thanks !
Kneedeep (05-31-2021)
Old 05-31-2021, 09:19 PM   #4
TheProfessor
Thanks !
Have used wood filler or wood putty on some cosmetic issues. Was OK. But didn't hold up in the long run.
Ultimately, ended up replacing the wood pieces in the end.
Old 06-03-2021, 07:02 AM   #5
Hi Kneedeep - What's your background are you a "handyman" or "carpenter?" Thanks...
Old 06-03-2021, 07:42 AM   #6
Kneedeep
Handyman with 30 years of experience.
The Following User Says Thank You to Kneedeep For This Useful Post:
dpg (06-04-2021)
This page was generated in 0.08039 seconds
