Old 09-29-2017, 05:37 PM   #1
rsnews
Default Surveyor needed
Any recommendations to get my lot lines staked out and a plot plan
rsnews is offline   Reply With Quote
Old 09-29-2017, 05:44 PM   #2
RUGMAN
I used Bryan Bailey out of Gilford, Nice guy and did a good job with my complicated plan.
Old 09-29-2017, 07:05 PM   #3
mneck1814
We have used David Dolan in Moultonborough, he was great!
mneck1814 is offline   Reply With Quote
Old 09-29-2017, 07:27 PM   #4
winni83
Ditto for Dave Dolan.
Old 09-30-2017, 10:37 AM   #5
Spider Girl
Spider Girl's Avatar
Default Surveyor Needed
Recommend Carl Johnson, Advanced Land Surveying Consultants, Meredith.
Spider Girl
Spider Girl is offline   Reply With Quote
Old 10-01-2017, 06:51 AM   #6
KDL
We just used Jones & Beach.
Old 10-04-2017, 09:57 AM   #7
TheProfessor
Not enough information.
If your lot has been staked - a good metal detector will find the existing stakes.
If you are sub-dividing a lot then yes you will need a surveyor.
Hambrook in Sandwich is another. I used Hambook to find my pins. All he used was a good metal detector.
Old 10-04-2017, 11:03 AM   #8
Not enough info?? Poster's looking for his land to be staked out pretty straight forward.
Old 10-04-2017, 01:44 PM   #9
Pricestavern
Pricestavern's Avatar
Exclamation Not Good Enough
I would not trust a metal detector as the sole source of finding and positively identifying property markers. First off, not all markers are metal pins, many are locust stakes. Secondly, and more important - finding a marker in the area in which you think it might be is not good enough proof of lot line. Any good surveyor will tie it in to other stakes, pins, and more importantly monuments to prove-out the location and compare actual vs planned.
Old 10-06-2017, 06:10 PM   #10
TheProfessor
Not sure if you read my entire post.
But below is the original post.
"Any recommendations to get my lot lines staked out and a plot plan."
Is OP subdividing property or just seeking his pins? If there are pins, then a metal detector will find them. If OP needs new pins, then of course he will need a surveyor. A plot plan can be had at the town hall.
What is the reason or needs of OP? Not clear.
And I did state the name of a qualified surveyor in my post.
Whew !
This page was generated in 0.28062 seconds
