Surveyor needed
Any recommendations to get my lot lines staked out and a plot plan
I used Bryan Bailey out of Gilford, Nice guy and did a good job with my complicated plan.
We have used David Dolan in Moultonborough, he was great!
Ditto for Dave Dolan.
Surveyor Needed
Recommend Carl Johnson, Advanced Land Surveying Consultants, Meredith.
We just used Jones & Beach.
If your lot has been staked - a good metal detector will find the existing stakes. If you are sub-dividing a lot then yes you will need a surveyor. Hambrook in Sandwich is another. I used Hambook to find my pins. All he used was a good metal detector. |
Not Good Enough
But below is the original post. "Any recommendations to get my lot lines staked out and a plot plan." Not enough information. Is OP subdividing property or just seeking his pins? If there are pins, then a metal detector will find them. If OP needs new pins, then of course he will need a surveyor. A plot plan can be had at the town hall. What is the reason or needs of OP? Not clear. And I did state the name of a qualified surveyor in my post. Whew ! |
| All times are GMT -4. The time now is 08:40 AM. |
