I had the opportunity morning to witness the M/S Mount Washington being pulled up on to land. Are there more upgrades taking place this year?
DMJR Moultonborough, NH |
Are there photos available showing the dry dock process this year?
The ship has been pulled to paint the bottom
I live for a rag top day
WBB,
I notice that the Mount isn't pulled every winter into drydock. Is there some benefit to leaving in the lake over the winter, or is it just the cost of pulling it up that is the issue? |
They pull it out about every 5 years to "kick the tires" ... and do any needed hull work, prop work and paint the bottom.
... or is it every 4 years ... memory it the second thing to fail and I forget what the first is.
Moderator
| The Following 2 Users Say Thank You to webmaster For This Useful Post: | ||
ILoveWinnipesaukee (11-05-2010), Rattlesnake Gal (11-08-2010) | ||
Thanks for the replies. I understand there is a schedule for maintenance. However, my question remains. Is there some benefit to leaving it in the lake over the winter? Most boats are pulled out of the water in the winter, every winter. Isn't it better to pull the Mount too? The bubblers most cost them something to run all winter. Or is this method less costly than pulling it?
Where is that?
"The true meaning of life is to plant trees, under whose shade you do not expect to sit." Nelson Henderson (1865-1943) |
Center Harbor.
"You're only young once, but you can be immature forever." |
The boat is much happier in the water, as you can imagine it's best to have the weight distributed across the entirety of the hull surface. On the cradle it is distributed only down the keel and and certain strategic points by bilge blocks.
| The Following 2 Users Say Thank You to WeirsBeachBoater For This Useful Post: | ||
Pineedles (11-06-2010), Rattlesnake Gal (11-08-2010) | ||
Along with my "thanks", that I attached. I wanted to reply with a thank you WBB. That makes sense. I knew a crew member would have the answer.
| The Following User Says Thank You to Pineedles For This Useful Post: | ||
WeirsBeachBoater (11-07-2010) | ||
They even left it in the water when removing the old and installing the new engines this year. They keep a few heavy-duty bubblers running around it, and it just bobs in its own little pond of open water, surrounded by bob houses.
"When I die, please don't let my wife sell my dive gear for what I told her I paid for it." |
Do they,
Bob Bob Bob, Bob House around? |
Came out when I was just being born into this world...
![]() That had the florescent front lighting. Now they have LED back lighting....Funny. |
| The Following User Says Thank You to Lakesrider For This Useful Post: | ||
Cal (11-10-2010) | ||
