-   -   M/S Mount Washington on land (https://www.winnipesaukee.com/forums/showthread.php?t=11103)
dmjr 11-03-2010 04:13 PM
I had the opportunity morning to witness the M/S Mount Washington being pulled up on to land. Are there more upgrades taking place this year?
Grady223 11-04-2010 03:37 PM
Are there photos available showing the dry dock process this year?
Rag Top Daze 11-04-2010 06:24 PM
Maintenance
The ship has been pulled to paint the bottom
WeirsBeachBoater 11-04-2010 07:09 PM
Here you go
1 Attachment(s)
As seen on WMUR tonight at 6pm.
Pineedles 11-05-2010 01:02 PM
Dry Docking vs. In lake
WBB,
I notice that the Mount isn't pulled every winter into drydock. Is there some benefit to leaving in the lake over the winter, or is it just the cost of pulling it up that is the issue?
RI Swamp Yankee 11-05-2010 01:38 PM
They pull it out about every 5 years to "kick the tires" ... and do any needed hull work, prop work and paint the bottom.
... or is it every 4 years ... memory it the second thing to fail and I forget what the first is.
webmaster 11-05-2010 01:45 PM
http://www.winnipesaukee.com/index.php?pageid=drydock
Pineedles 11-05-2010 04:37 PM
Thanks for the replies. I understand there is a schedule for maintenance. However, my question remains. Is there some benefit to leaving it in the lake over the winter? Most boats are pulled out of the water in the winter, every winter. Isn't it better to pull the Mount too? The bubblers most cost them something to run all winter. Or is this method less costly than pulling it?
Airedale1 11-05-2010 05:31 PM
Where is that?
Newbiesaukee 11-05-2010 06:02 PM
Center Harbor.
WeirsBeachBoater 11-06-2010 10:01 AM
The boat is much happier in the water, as you can imagine it's best to have the weight distributed across the entirety of the hull surface. On the cradle it is distributed only down the keel and and certain strategic points by bilge blocks.
Pineedles 11-06-2010 07:24 PM
Along with my "thanks", that I attached. I wanted to reply with a thank you WBB. That makes sense. I knew a crew member would have the answer.:)
Grant 11-09-2010 04:29 PM
They even left it in the water when removing the old and installing the new engines this year. They keep a few heavy-duty bubblers running around it, and it just bobs in its own little pond of open water, surrounded by bob houses.
Pineedles 11-09-2010 04:34 PM
Do they,
Bob Bob Bob, Bob House around?
NoBozo 11-09-2010 08:35 PM
Originally Posted by Pineedles (Post 143526)
Do they,
I think that was Steve Allen...Bob Bob Arang...:D :D NB
At my advancing age...I can still remember. :) :) We had a big 17 inch Black & White Sylvania Halo Lite TV. ....1958..??
Lakesrider 11-10-2010 11:03 AM
Came out when I was just being born into this world...:D
http://www.tvhistory.tv/1950s_Sylvan...el_21C529B.JPG
That had the florescent front lighting. Now they have LED back lighting....Funny.
