12-22-2009, 08:17 PM | #1 |
Roof Ice Damming
I came home this afternoon (22-Dec) to the sound of water dripping inside my front bay window, " ICE DAMMING " on the roof. My question to the forum is other than a metal roof or heating cables, does anyone have any ideas on how to end this problem. I did clean the gutters and downspouts in late November. The roof has a 5/12 pitch and is north facing. Should I just go out and buy a Snow Roof Rake and if so where, or is there a less dangerous ( no ladder ) solution available ... Thank You
12-22-2009, 08:53 PM | #2 |
The only way to prevent ice damming is by proper insulation during construction. Proper soffit vents and baffles. You should try to prevent any heat loss to the attic. Seal attic doors, make sure your bathroom vents don't empty into the attic, etc... Are you keeping the house too warm? There is only adding more insulation to the attic if possible. If not heat cables are the best way to prevent a load of ice on/in the gutters. I occasionally will get a drip or two of water coming in from my skylights. Same deal, heat loss through the windows melts the snow and causes ice to form next to the window. Bad flashing can allow the ice underneath and the drips. I have a North facing roof so know your pain. I too roof rake the snow as best as possible near the edge of the roof.
12-22-2009, 09:28 PM | #3 |
I agree with Lakesrider. We resolved our ice dam problems by having a contractor re-insulate the area underneath the part of the roof where the problems were occurring.
Besides adequate insulation, you also need enough space between the insulation and the roof sheathing for outside air to circulate through the soffet vents and under the roof. The air in that space needs to stay cool. Is this your first winter in a new house, or a house that you've spent many winters in and this is the first time this problem has happened? |
12-22-2009, 09:39 PM | #4 |
what we have
This is our second winter and the first with a problem. The inspection report states the house was built in 1977. The roof was stripped and re-shingled in 1997. but It does not have any of that rubberized water shield material ( roll type ) along the drip edge, under the shingles, just felt paper. It has gable end vents (2) and a 50 foot long ridge vent with no attic fan. The roof is truss construction, 2 feet on center with approx six inches of settled insulation. All vintage 1977 building and energy code standards.
12-22-2009, 10:08 PM | #5 |
The fact you didn't have a problem last year certainly wasn't because of a lack of snow!
All I can tell you is that we had 2 roll-widths of bituthene installed when we replaced our roof. But until we finally fixed the insulation, we still had water coming in (above the upper edge of the bituthene). Any contractors on the forum who can shed some light on the original poster's problem? |
12-22-2009, 10:22 PM | #6 |
Very Good Advise By Lakesrider & beaner...
Winni-Retired
For this winter, I would purchase some good thermostatically controlled heat tapes to get you out of the woods for now... Maybe a heat loss evaluation could pick up any problem areas, that could be addressed with insulation at a more favorable time of year. I feel for you as I would leave on a two week snowmobile trip only to return home to find ice dams had formed and damaged the interior walls with water leakage. Very definitely, keeping the roof temp closely related, inside and out through insulation and soffit venting is the cure. Best wishes, Terry
12-22-2009, 11:39 PM | #7 |
Just my opinion
In general it is good practice to minimize the heat loss to the roof to reduce ice dams. However, I don't think that this will completely preclude them. Ice dams can form due to heat loss due to leakage from the house or solar heating when a portion of the roof is exposed to the sun (the snow scrubs down from the top of the roof). The following article gives a good overview of causes and remediation.
http://www.balancedsolutions.com/web...amDocument.htm We developed a leak in our roof last winter. The immediate remediation was to put some heating tape in the location of the ice dam. That prevented the ice dam from forming and allowed the water to drain off the roof. During the summer a neighbor (contractor) stripped the shingles and found a gap in the bituthene. Repairing the bituthene was the corrective action. Most roofs in this area use a complete layer of bituthene under the shingles to prevent leakage due to ice dams. Other measures are only partially corrective (IMHO). Jetskier |
12-23-2009, 07:43 AM | #8 |
Clarification...
Just as a clarification and not really adding to the good advice above, the "bituthene" being referrred to above is lovingly referred to by contractors as "B*tchaThane" because it is a b*tch to work with. It is an extremely thick and sticky, on one side, rolled membrane that nearly all roofing contractors use these days when roofing. W.R. Grace was one of the first to come out with it in the 80's and it is on the shelf at Home Depot and Lowes as "Ice and Water Shield". It comes in rolls that are 3 feet wide similar to felt paper.
In my own personal case, I had my roof done in the mid 80's and we used this product. The standard back then was just to do one layer/run 3 feet up from the eaves. Now a days I see many roof jobs where this product is used the whole way up the roof and I opted to do this myself when I had my roof done again this past summer. BT
12-23-2009, 08:39 AM | #9 | |
The Stuff Works
BTW, our contractor referred to it just as BT stated!
DRH |
12-23-2009, 09:37 AM | #10 |
Bituthane or Ice and Water sheld is a big neccesity. Every roofing contractor I know.... recomentds going up six feet. Now I say roofing contractor, because the are general contractors that will do roofs, and then there are guys that specialize in roofs. I have now had 3 different Roofs done in the last 5 years, in different locations. Each time the work was performed buy a roofing contractor. They all incude 6 feet in there estimates. They will do the whole thing as BT did. However 6 feet is probably more then enough. And then jsut felt above that for the rest of the roof.
Now just a little more information here. The reason the Bituthane is important is that unlike felt which will tare, thus allowing moisture through, the Bituthane, as it heats up, seals around all the nail holes, and really bonds with the shingles. Thus it creates a nice solid barrier after a summer in the sun. It will also seal up any small litte tares that happend durring an ice build up. All in all it is a great roofing product. now back to Winni-retireds bay window. These are and always have been problematic. Much like sky lights.... as others here have said, try and find a way to get through this winter... I don't have any further suggestion on then what is mentioned here.... Then come spring have all the flashing checked, and maybe re-roof the bay window. I assume the Bay window has its own little roof. Ventilation is not an option, you just have to have a good seal around the window.
12-23-2009, 10:16 AM | #11 |
All good advice here. 99% of the time ice and water shield installed at least 3 feet higher than the unheated portion of the roof will prevent any water from entering if dams occur. When I reroofed 7 years ago I did to 2 courses of I&WS and also in the valleys. This fixed my ice dam leaking problem without addressing the insulation. The quick fix during the winter I had the problem was to install heat cable, even if it's not put up perfect. As soon as the cable melted down to the roof the flood gates opened and the water stopped backing in.
SIKSUKR |
12-23-2009, 12:01 PM | #12 |
Lots of practical experience in these excellent suggestions. If you need a short-term solution until you get things fixed, you might do what I did.
Two winters ago I had an ice-damming problem. I wasn't able to resolve the problem right away so last winter I used the roof rake after every storm, clearing back about 10 feet from the edge of my roof. I only had to do the front roof facing west towards the sun (the back of the house is a dormer and there were no problems there). Using the roof rake took me about 15-20 minutes at most and there were no more leaking problems. As I said, that was a temporary solution. It might work for you. Good luck! -- Sky |
12-23-2009, 12:20 PM | #13 |
Looks like a plan
Off to home depot this afternoon to get a roof snow shovel and roof heater cable .. will drag off the snow then lay the cable on the roof, gutter and wrap around downspot. Mission will be to get the gutter water flowing and correct the problem in a more controlled enviroment in the spring.
I greatly appreciate the information and guidance that was offered, as we try to keep the water outside and the window dry on the inside. Thank you all |
12-23-2009, 12:25 PM | #14 |
LOL...I'm just lucky I guess, that my North side roof is the low roof. I have a Salt Box/Cape style home. If the back was the North Side I'd have to get up on a tall ladder to clear the roof.....Yikes...I'd just move to Airizona if I had to keep doing that!
12-23-2009, 02:28 PM | #15 |
Salt
Though not something I would do on a longtime basis, you could also put a couple lines of rocksalt from above the ice to the roof edge to melt a pathway for the water. It worked for me.
SIKSUKR |
12-23-2009, 02:40 PM | #16 |
As a temporary solution, removing the gutters (aluminum I would assume) will help to allow the water to drain off easily. Then replacing the gutters with those not at the fascia but suspended below the eaves helps.
12-23-2009, 05:27 PM | #17 |
Rake this winter, install Grace this spring
If you are having problems this winter, purchase a roof rake to get the snow off the roof. You don't have to go all the way up, just try about half way or so. In the spring time, you should redo your roof and have the Grace Water and Ice Shield underlayment installed directly on the roof deck. My father used to break his back trying to rake it off and then when the dams did form, he basically ruined the roof by hitting it with a hammer.
Two websites: The first one is your solution and the other one is a local newspaper article about ice dams and some solutions. http://www.graceathome.com/pages/roofing.htm http://www.citizen.com/apps/pbcs.dll...WS02/703059790 |
12-24-2009, 09:33 AM | #18 |
Only a couple of things to add.
Winni, you stated that you have two gable end vents and a ridge vent, but no mention of soffit vent. If you in fact have venting in your soffits, you need to remove the two gable end vents, they are disrupting the airflow in the attic. Gable vents are an inefficient form of creating cross ventilation and I say that only because most are completely undersized to create enough air flow to satisfy demand for removal. Soffit vents and roof vents work together to allow a proper flow of hot air escaping the roof and not creating warm air pockets that melt the snow on the roof. If you do not have soffit vents then you have what you have, it would not be cost effective to have someone install them. You also mentioned that you have six inches of insulation on the attic floor. Is this blown in (loose, wool looking) or fiberglass batt. And are you sure there is only one layer. The reason I ask is loose insulation and fiberglass batt at a thickness of 6" is only R-19 of insulating value. NH PUC Code on current residential construction is R-38, that is 12" of standard fiberglass or loose fill and just under 7" of high density foam. If it was my house and this was an issue that I had, I would have foam insulation installed in the rafter bays and eliminate the insulation on the attic floor. The foam gives far supperior insulating values and does not require ventilation between the insulation and the roof. You will also get at a minimum of a 10 year warranty on this product and it will never change in R-value as loose and fiberglass will. As far as installing Bitumen on your roof, one it sounds like you only have an issue with the bay window, so deal with that unless the roof is in terrible shape on the rest of the house. Installing Bitumen on the entire sub-surface of a roof is commonly known in the trade as protecting against a poor installation. Most roofing manufacturers will not honor their warranties on the shingles if they have been installed over nothing but Bitumen. They main reason is that the Ice and Water shield heats up more than Tri-flex 30 or felt paper (not much felt being used these days but you still see it from time to time), this causes the shingles to breakdown prematurely. Industry standard for installation of Bitumen is 6 feet off the eaves and 3 feet out of the valleys, it will also typically be installed in areas of complex roof line meetings or up cheek walls on dormers (with standard step flashing above to protect the membrane. (I am not trying to say anyone else did a bad thing by having Ice and Water installed over the entire roof, but these are a few things that you may not have been made aware of at the time.) As far as shoveling off a roof to clear an ice dam, there is one important thing to know when it comes to ice dams. Ice dams form when melted snow or ice runs down the roof and comes in contact with freezing cold air. If you rake off the bottom 4 feet of snow, the ice dam will move up the roof 4 feet. If you are going to clear the snow off your roof, do the whole thing, it will be easier in the long run (having to do it all winter) as the ice pockets will be slim to none. If you are not interested in climbing on the roof to do this than ask and family member or neighbor that is. Good hot soup throughout the winter is allows a fine payment in my book as long as things are held in this capacity, don't try to pay a contractor with a bowl of soup if you have to hire someone. The possible main cause for the issue with your bay window is a lack of insulation within the bay roof itself (unless the bay roof is an extention of the main roof above), contact an experienced finish carpenter as this can be remedied from the inside, but make sure they are aware of what you are looking for and know how to properly insulate the space, there is no ventilation in a bay window roof, so you will want them to install a 2 in foam board layer directly touching the roof sheathing, then LOOSELY pack fiberglass insulation into the remaining cavity. If fiberglass insulation is crushed below the thickness stated for the R-value then it will loose its insulating quality. Just like wearing layers of clothing, you will be warmer by wearing loose fitting layers than wearing 6 shirts under a jacket. Make sure that the leak issue is resolved first, it is always easier to determine the source of a roof leak from below the roof than above. Roof repairs can be perfomed in the winter so this is an issue that can be resolved before spring. Good luck with resolving your issue. |
12-27-2009, 10:53 AM | #19 |
Just to add a statement to posts. You must have efficient soffit vents, with free flow of air. The insulation should never contact under side of roof.
The "attic" space should be as close to the outside temps as possible. With combination of insulation and ventilation, that will happen. If it becomes necessary to replace roof shingles, I found that metal roofing was my solution! I researched, and selected a contractor who does only roofing; there are no nails or grommets visible; no fasteners are exposed. The exact term evades me: installation starts on one end and the pieces cut & crimped on site are layed together like clapboards starting at bottom. The strips are about 20" wide, starting at eaves and up to ridge or a valley. I was fortunate that my roof had only one layer of shingles, so the new roofing went down on top, and I was not liable for removal & disposal of old materials! There is bad info out there. It did cost me more that re-roofing shingles, but not twice. One really needs to do homework for their particular situation. I have a few areas of very low pitch, and I used to shovel it off; NOW I never ever plan to go up and shovel roof! Because I selected a color which absorbs the least heat, in the summer, the spaces to not heat up as much as before. I vote for my own safety, and after having two major leaks, I have no leaks. |
12-27-2009, 10:16 PM | #20 |
DO NOT make a claim
Do not make a claim UNLESS you think you MUST. P&C Insurers (Property & Casualty) are NOTORIOUS for canceling your property coverage if you so much as even burp about a loss-no kidding. I mean they WILL cancel you in a New York minute-believe it-for the most minimal of claims.
My family has owned a house in Weston, MA (valued at about $1.3M) which we built in 1960-and in 50 years of ownership ("fifty") have never had a claim-NOT ONE. My parents had hot/cold water faucets in the garage-for some reason after their deaths in 2008 while the house was vacant-the garage door was found open when my plow-guy came in one night to do his thing and told me about it-he knew the parents had passed, and that the house was vacant, hence his call to me as to why the garage door was open (a mystery to this day, among other odd happenings). Bottom line: cold weather burst one of the pipes in the garage due to the door being open and sent water into the basement-our primary point of access to the house off the driveway. While my father the mechanical engineer had the foresight to install drains in both the garage and the furnace room off the garage adjacent to the basement-and the fact that only 1" of water had accumulated causing "minimal" damage-we got screwed on the spot by the-and I use this term loosely-"Insurer". Major dirtbags-and the local agent in Wellesley MA was useless on this issue. Claim paid ($3,500+-), then the policy was promptly canceled by them. Please take my warning to heart-this is accurate information, although you never really know what these dirt-bag P&C Insurers will do....think "Katrina" if you want an earful.... |
12-27-2009, 11:00 PM | #21 |
I must agree to disagree
I had a roof leak, and the only smart thing to do was re-roof. I thought about metal, but I have a lot of trees close to the house, and our bedroom is right under the roof, no floor to cut down on the noise of heavy rain on it. So we went with 30 year architectual shingles.
My installer made his estimate for the roof, and also he arranged for the work inside to be done. I filed with the insurance company (Concord Group= great service.) They paid for a company to come in and assess the amount of water damage, who removed damaged sheetrock and paneling that would have mildewed due to its saturated nature. My estimate for the interior work included redoing one wall, the entire dining room ceiling (ceiling tiles of three different widths no longer in production) with sheetrock, and painting the dining room. All told was over $3000. The roofer, in his estimate attributed approximately ten percent of the roof area would have had to have been replaced to repair the damage, and the company also paid me over $1100. Total claim was over $4000 less my $1000 deductible, all with no hassle, and I renewed this summer with no problem. Diver1111, first I am sorry for your loss, and in my prior life I was a personal lines underwriter for a P & C company. I suspect the main reason the policy on your parent's home was cancelled was not because of the claim, but rather the house was unoccupied and the claim brought this information to the attention of the company. Those are tough (really, underwriters do have a heart, contrary to popular opinion) decisions to make, because in most states, you can only cancel a policy at the renewal date, and with a specific number of days notice. To continue a homeowner policy beyond a renewal, when the home is unoccupied, would cause the insurance company to violate at least one condition of issuing a homeowner policy, that being issuing it on a dwelling that is not owner occupied. One thing that I (we) always looked at in evaluating claims was asking the question: Is the homeowner using the policy as a maintenance contract, that is making a bunch of small claims. If the answer was yes, it was good bye to that claim. We had numerous occasions where an insured would have a total fire loss, hundreds of thousands of dollars, and we would write the new policy. Why? Because the insured had a good record and the only loss was catastrophic. From my end, if you have a loss and feel you need to file a claim, make sure it is substantial and that you are not appearing to be rebuilding your home a room at a time.
trfour (12-28-2009) |
12-28-2009, 03:34 PM | #22 |
Agree Upthesaukee
40 years in insurance - I would agree, the reason for the cancellation was because the home was unoccupied.
As you all can imagine, a home that never has anyone at home is a much bigger risk for a loss than one that is occupied. Diver111, if someone had been at home the likelihood is that the damage would have never progressed to the point that there was a claim. |
The Following User Says Thank You to Grady223 For This Useful Post: | ||
jeffatsquam (12-28-2009) |
