Hi...can anyone help me with multiquotes? I read how to multiquote in Faq but can't seem to find the multiquote icon ...thanks
Also inserting an image that is not in the photo gallery.
#3 | |
[QUOTE=sunset on the dock;111544] text I left out the end part so you could see it. If I were to put the following /QUOTE inside these brackets [ ] at the end of the quoted statement or in this case the word "text" it would look like this: So that allows you to manually quote someone by going back in the thread, which by the way is conveniently underneath the text box you are typing in, and cut and paste quotes that you want to use. All you have to do is wrap the text in: [QUOTE=sunset on the dock;111544] followed by /QUOTE inside these brackets [ ] That's how I do it but I am not sure it is the easy way.
#4 | ||
Moderator
thanks...will give it a try.
#7 | |
Getting ready for winter! |
I would imagine that some folks abused it.
Understatement of the month...
[insert witty phrase here] |
I just use the quote function and use the copy function to snag the quote. Next I use the "back" button to ignore out of it and go back to the thread. Then I use the quote button on the second post and paste the first quote into that window. Then paraphrase and add comments as desired.
Good luck! |
If there is any feature that is abused in abundance, it is the "Quote" feature!
![]() If you're going to add a reply directly after the previous post, why quote the previous quote? ![]() When the need arises to address more than one thought here, you'll notice the Webmaster uses the multi-quote feature.
It's seems like its Always People Supersizing posts.
SIKSUKR |
Well, I think this is A Proper Solution to the original problem.
#17 |
Its Always Perfectly Sane And Polite Subcribers to A Policy Statement by An equally Polite and Sane webmaster that are hurt when Adjusted Policies of Subscriptions must be endured.
#19 |
...I can't be certain...
![]() (...and one has disappeared...! )As I'm sure Don will acknowledge, I "sorta" invented the multi-quote before it became a forum application here—and applied it similarly as Hazelnut has described it. The multi-quote button appeared more widespread later and can be found on the tiniest forums on the Internet. (Bradley Green Entertainment, for example). Those who can't master the multi-quote can cause a different "problem": On one recent page, one member has ended up with 80% of the replies! (I'd previously described that entire thread as a "Vanity" and a "chatroom"—"chat" being discouraged in the rules here). Without multi-quoting—a single page has one member's replies saying essentially the same thing! (and are 40% of the replies on that page ). As some of us noted, the absense of "multi-quote" didn't stop member elchase. (My own most-recent replies use a morphed, and "kinder-and-gentler" multi-quote).As for myself, I've failed to master the entry into this site's "Blog" pages, which could greatly shorten all of our replies. (Just by using the hyper-link feature to link to those entries). Anyway, "The Story of My Life on the Internet" is best illustrated below: ![]()
#20 |
Groan...Another Pun Stuffed thread.
#21 |
It sounds like were picking on A Paticular Someone but Every Lake lover website has one spammer.
SIKSUKR |
#22 |
This is what his wife said to him at the end of the conversation:
OK sweetheart, And Please Shut the lights off before you go to bed, we don't want to waste ELectricity!!
