Old 06-30-2009, 12:47 PM   #1
AMC
Default Pressure Washing/Cleaning
I need a bunch of metal roofs on my property pressure washed can anyone recomend someone that is reliable and can complete the job in a timely manner?
AMC is offline   Reply With Quote
Old 07-01-2009, 08:19 AM   #2
fpartri497
Paul Drouin Is the man to contact. unfortunatley I dont know his number. he does pressure washing all around the lake. told me that he pressure washes Bob bahire Mcmansion monthly.
he drives a Chrysler mini van with his name and number on the rear windows. I know this info because I sell him his pressure washers at sears.
fpartri497
dont worry be happy
Old 07-01-2009, 09:39 AM   #3
Woodsy
Default Bob Powell!!
Give Bob Powell a call.... he does painting and pressure washing. He has a boat so island access is not a problem. VERY reasonable rates, insured etc... He has done more than a few jobs for forum members, myself included!
His number is 603-520-5658
Tell him Woodsy sent ya!
Old 07-01-2009, 02:52 PM   #4
What is the benefit to using a pressure washer?
At least for removing mildew/mold from flat surfaces like a dock or deck; wood, cement, tile, or plastic, doesn't a mix of water and clorox applied with a sponge or ten dollar garden style hand pump sprayer do the same job without using high pressure water. You just spray it on a sunny day, let it dry, and the mold will disappear from a wood railing or deck.
Probably, there is a good use for a high pressure washer that I don't know about?
Old 07-01-2009, 04:03 PM   #5
NightWing
NightWing's Avatar
Talking
A pressure washer in the hands of an inexperienced user can rip the vinyl siding off a house, blow shingles off a roof and even knock old mortar out of brickwork.
That being said, I hired a guy who has a P/W business (not near the lake) and he did a flawless job, although the cost was over $500 for a small to medium size house and free standing garage. He spent most of a day on the job.
In the dead of night they come - Swift - Silent - Savage
Old 07-01-2009, 08:44 PM   #6
Talking Me 'n' Tim...
"...What is the benefit to using a pressure washer?...Probably, there is a good use for a high pressure washer that I don't know about..."
As a brand-new landlord, I felt justified in spending $1500 for a brand-new pressure washer: As advertised, I realized that it pumped 1300-psi.
(That's a LOT! Don't ever aim the spray at your bare feet!!!)
What I didn't realize, was that it pumped 8 gallons per minute!
There's no garden hose that can supply that kind of volume, so I had to attach two garden hoses—one from a willing neighbor, and one from the house. (8-gpm will pull down a single garden hose flat in 30 seconds).
The rate of high-pressure water was so great, that the replaceable fittings would show wear inside!
Anyway, it's such a handy cleaning tool, you'll find things to clean with it 'til you wear yourself out.
After an afternoon of:
1) removing paint from concrete,
2) digging trenches in the yard,
3) removing vines from the fence,
4) cleaning all the gravel in the driveway,
5) cleaning the roof,
6) cleaning the concrete garage floor,
7) cleaning the wheels of all the cars, (and especially whitewalls, if you have 'em—as I did),
8) driving 4x4s into the lake bottom for your dock,
9) frightening squirrels away (my dogs wouldn't get anywhere near my pressure-washer,
10) removing algae and mildew from decks,
11) removing lichens from trees and boulders,
12) blasting Autumn's leaves into piles,
13) unintentionally removing the decals from the sides of my truck
14) cleaning under the hood,
15) blasting all the cobwebs out from under the eaves,
16) cleaning windows on the 1st and 2nd floors
17) cleaning the undersides, differentials and transmissions of all the cars, you can just...
18) spray high-pressure water up in the air for 50-feet—for a quick, misting cool-off of everything surrounding you.
19) Drive nails. (No forget that, it didn't drive nails).
If the dock needed a less-slippery surface, the pressure-washer I had would rip-up the grain of the wood!
Gee, I miss that washer!
(Tim Allen would've too...).
Is it
"Common Sense" isn't.
Old 07-01-2009, 11:24 PM   #7
Bear Island South
Bear Island South's Avatar
Default Acres Per Second
That is hilarious...thanks for the laugh
and I believe every word of it, I have used on on those.
Old 07-02-2009, 10:38 PM   #8
trfour's Avatar
Default Acres....
Why didn't you say something, I would have sold this puppy to you for $500.00.
The guy that gave it to me said it wouldn't run. When I brought it home and took a look at it, I guess he thought, being a pressure washer, that water is what they put in the gas tank. I drained the fuel tank and carb bowl,
flushed out the system with carb cleaner put fresh gas in and walah, it started right up with half a pull on the starter rope, and purrrrd' like a kitten! Then I hooked up a garden hose and ran it to check out the pump and I'm going to tell you something, "This thing could end the war in Afghanastan, from my back yard"!!
Pictures, Big Ben, and Osama Who?
Last edited by trfour; 07-04-2009 at 01:44 AM. Reason: I used to win spelling beez in school, however, for the Life in me....??
Old 07-05-2009, 01:45 AM   #9
FEZZ INC
Default Home Maintenance
I Contract for a lakefront builder around the Lake and pick up home maintenance jobs on the side. Sounds like a simple job. I have a pontoon boat that I take around to different Islands to do work(If you are on an island). I can beat anyones price and I'm reliable. 6033872467
Pat
FEZZ INC is offline   Reply With Quote
This page was generated in 0.08138 seconds
