Old 03-17-2009, 08:42 PM   #1
Irish mist
Default Mice......again
looks like I have a mouse problem. I'm in a first floor condo. My unit seems tight, but my guess is they are coming in from the back hallway door which is not flush on the botton (I have called management to have this issue fixed). I have those plug-ins, so that's done. I guess I'm just going to have to buy some D-Con and glue-board. Any other suggestions on how to deal with this problem ? I killed the mouse tonight right from my stuffed chair by hitting it with my TV remote control, lol.....I'm not kidding here
________
One Vaporizer Reviews
Old 03-17-2009, 11:25 PM   #2
Default Sneaky little rascals
Mice only need less than a quarter of an inch to enter an area.
Set your traps, or go to the Humane Society and get a car .
Shameless plug for our area Humane Societies !
Any little openings can be sealed with steel wool, and they will not try to come through it, although from an energy perspective, maybe some of that foam would be better.
Old 03-17-2009, 11:36 PM   #3
Irish mist
I really thnk they are coming in from the hallway of the condo and under my door, but who knows ?
________
HONDA CMX250C
Old 03-18-2009, 06:49 AM   #4
Default Traps and Poison Everywhere
That's really the only way to control/eliminate mice. Bugs are more easily controlled as staying on a schedule of controlled sprays will stop them. Mice can get in lots of spaces and will travel most anywhere.
Old 03-18-2009, 06:55 AM   #5
chipj29
chipj29's Avatar
One thing I have heard is that mice and rodents typically travel along walls. That way they can walk in the dark using their whiskers to "see" where they are going. I would suggest putting a trap just inside the door you suspect is the problem. One on each side of the door right against the adjacent wall.
Getting ready for winter!
Old 03-18-2009, 07:31 AM   #6
Irish mist
Yes, I'm putting the traps against the walls, near the door, near the fridge, and putting D-Con everywhere. Now I just have to get the condo association to fix the outside door. That is like talking to a wall I'm afraid
________
Herbalaire
Old 03-18-2009, 08:00 AM   #7
You could buy a door 'broom' strip and surreptitiously install it to the offending door. I don't know if it would work but it's worth a try. I understand this door is probably the association's responsibility but you are the one who seems to be botherred and will continue to be botherred until someone takes action.
If you want to be a P.I.T.A., check with your local health/code enforcement officer. They may be able to encourage the association to deal witha vermin infestation. Since publicity about "vermin infestations" can make it harder to market properties, the other members of the association may be more willing to discuss solving the problem if you put it in those terms.
Old 03-18-2009, 08:32 AM   #8
Default I Dunno...
Originally Posted by dpg View Post
"...Mice can get in lots of spaces and will travel most anywhere..."
They're also developing countermeasures:
Is it
"Common Sense" isn't.
Old 03-18-2009, 09:54 AM   #9
Irish mist
Good idae Thanks for the info.
________
Ford Fusion Specifications
Old 03-18-2009, 01:50 PM   #10
4 for Boating
Just to toss in another aspect from my own experience, if D-Con is used, the mice will seek water prior to dying. So, if they are inside your home, don’t be surprised if they end up floating in your toilet. This can be countered by putting aluminum foil over the base opening of your toilet but this would be a bit of a headache if you are in the home full time and not in a seasonal or weekend type thing.
Good Luck!
4 for Boating is offline   Reply With Quote
Old 03-18-2009, 02:35 PM   #11
Irish mist
Originally Posted by 4 for Boating View Post
Just to toss in another aspect from my own experience, if D-Con is used, the mice will seek water prior to dying. So, if they are inside your home, don?t be surprised if they end up floating in your toilet. This can be countered by putting aluminum foil over the base opening of your toilet but this would be a bit of a headache if you are in the home full time and not in a seasonal or weekend type thing.
Good Luck!
Lol......yup it's my full-time house. I'll make sure to look in the toilet
________
Buy Vapor Tower
Old 03-19-2009, 12:15 AM   #12
NightWing
NightWing's Avatar
Talking
Another danger of using D-Con or any poison is that the mice might crawl into a wall and die. You will know it when the smell of dead mouse permeates your 2X4's and drywall.
Traps are tricky to set, at least the low quality traps on the market today.
However, there is a quick and (not too) dirty way to catch a whole herd of mice if necessary:
Get a 5 gallon plastic bucket and fill it half way with water. Smear peanut butter all around the inside rim. Take a plank of wood, maybe 6 inches wide and 3 feet long, and place one end overlapping the rim of the pail and the other end resting on the floor. The mice will scamper up the plank to get the peanut butter. Once at the top, they will try to maneuver into eating position, but will fall into the pail and drown.
It works. I had a trailer at a campground for a few years and mice were a problem. I would come up on weekends and usually had a half dozen mice in the bucket.
If you build it, they will come.
In the dead of night they come - Swift - Silent - Savage
The Following User Says Thank You to NightWing For This Useful Post:
Resident 2B (03-19-2009)
Old 03-19-2009, 01:17 AM   #13
Argie's Wife
Argie's Wife's Avatar
I have two cats I will rent out to you, if you're interested.
Old 03-19-2009, 03:35 AM   #14
Irish mist
Lol, all good advice I see I'm not the only one who is/has grappled with this problem.
________
Ford tempo history
Old 03-19-2009, 06:40 AM   #15
I prefer to use a shotgun,duct taped to the floor with a trip wire with cheese on the end.The neighbors hate it but it gets rid of the mice
SAMIAM is online now   Reply With Quote
Old 03-19-2009, 07:34 AM   #16
chipj29
chipj29's Avatar
When we first bought our house, we had a mouse problem. The cats loved it! They would chase the mice all night long (many sleepless nights for us). After not to long, the cats (which were indoor/outdoor cats) got lost out in the woods (fisher cats/coyotes) and never came back. Funny thing is...the mice never came back either. We figured that the cats would catch the mice outside, then bring them inside to play with them.
Old 03-19-2009, 09:46 PM   #17
Sunrise Point
We had a ton of mice when we purchased our camp. They evidently had the run of the place for years. I found that dryer sheets are a really effective deterrent. For some reason, they absolutely hate them. You could try putting a few on the floor near the door, or taping them so they hang over the gap at the bottom of the door.
Old 03-19-2009, 11:41 PM   #18
old coot
Good Luck!
What better place for a dead mouse than in the toilet, ready to be flushed?
oc
old coot is offline   Reply With Quote
Old 03-19-2009, 11:53 PM   #19
Irish mist
The condo association came and fixed the outside door today, much to my shock. My traps are empty, and the D-Con is untouched so far. The women in my house want results, lol, and fast, cause they are frightened to death of the mice. One of them will not go anywhere in the house without carrying around a broom to wack them with
________
Digital Vaporizer
Old 03-20-2009, 10:49 PM   #20
MaidenCove07
MaidenCove07's Avatar
Location: Manchester in Winter, Weirs Beach in Summer & Fall
.... or go to the Humane Society and get a cat .
It worked for me. Phoebe, the kitty is a great resource and (despite my not being a cat person) a great companion....and seeing as I bring her back each summer, her scent has done a pretty good job of keeping them at bay. I scatter baggies of "used" kitty litter in various spaces when I close up for the winter for more security and have had good luck, HOWEVER, now I seem to have a bat problem and their guano is disgusting!
MaidenCove07 is offline   Reply With Quote
Old 03-21-2009, 10:17 AM   #21
NightWing
NightWing's Avatar
Talking
Bat problem? Cannot be!
This page was generated in 0.10766 seconds
