Old 01-28-2008, 11:40 AM   #1
Old Hubbard Rd
Default Continued Site Issues??
Are people still having connectivity issues with this site?? I am!!
Old Hubbard Rd is offline   Reply With Quote
Old 01-28-2008, 11:45 AM   #2
JayDV
Default I think just a hiccup
Only briefly at 10:40 this morning (Mon 1/28/08) Didn't last and no probs 4 mins later
JayDV is offline   Reply With Quote
Old 01-28-2008, 12:06 PM   #3
webmaster
Moderator
webmaster's Avatar
The site is now running on a completely different server than it was a few weeks ago. The problems that were affecting the old server are gone and the site has been working well.
However, there is a big difference in the utilization of the server. Before we were running on our own server that, when it was working properly, had ample resources available. The response was very fast and the server was never even moderately loaded.
The new server is shared with many other sites and can be heavily loaded during busy times. The new server just can't process and reply as quickly as the old server when it is busy.
I have spoke to the host about the server loading and they will make adjustments over time to balance the load.
Old 01-31-2008, 04:54 PM   #4
webmaster
Moderator
webmaster's Avatar
Exclamation Today's Downtime
You may have noticed that the site was slow or unavailable for periods of time today. This was not a problem with the server. There was a major problem on the Global Crossing ISP backbone that created problems for the entire data center. This may also account for some short outages earlier in the week.
Some of you may recall that last year a backhoe accidentally dug up the feed to the data center causing almost an entire day of downtime. It's always something.
For now the problems have been resolved. Hopefully it will stay that way.
Old 02-03-2008, 06:38 PM   #5
Old Hubbard Rd
Default Still having issues
I was not able to connect to www.winnipesaukee.com all last PM and most of Sunday. Anyone else still having issues??
Old 02-03-2008, 07:51 PM   #6
Diana
I was able to connect each time I tried (frequently) yesterday and today...
Diana is offline   Reply With Quote
Old 02-03-2008, 08:07 PM   #7
RLW
RLW's Avatar
Count me in on the above quote
Old 02-04-2008, 01:59 PM   #8
KBoater
KBoater's Avatar
Default Connect
Same for me
Home Permanently in NH
Old 02-05-2008, 08:29 AM   #9
Old Hubbard Rd
Default Strange??
That's strange. Some folks can not connect and some can. I guess the access is limited to what the capacity of the server is. It appeared I never had issue months ago. These problems are all new to me as of the past 2-3 month.
Old 02-05-2008, 09:44 AM   #10
webmaster
Moderator
webmaster's Avatar
From the comments in this thread it seems like you are the only one who had trouble last weekend. My site monitoring report shows 100% uptime for last Saturday and Sunday and I was on the site for much of that time. Maybe there is a routing problem with your ISP.
Old 02-05-2008, 08:08 PM   #11
Old Hubbard Rd
Default It must be me
LOL It must be me!! I clicked a million times trying to connect that Sat & Sun. I could connect to every other web site except this one. That bummed me out as this one is my favorite!!
Old 02-06-2008, 09:37 AM   #12
fpartri497
Default site Issues?
Have you allready tried, dumping the cookies folder and the temp folder then rebooting?
dont worry be happy
Old 02-06-2008, 11:22 AM   #13
Old Hubbard Rd
Default Empty Temp & ookies
Thanks for the advice. I just dumped the cookies and temp files. Hope that helps!!
Old 02-06-2008, 07:58 PM   #14
wifi
wifi's Avatar
Boy, this discussion on speed laws will certainly help shake out any problems with the new server
Old 02-08-2008, 08:11 AM   #15
Old Hubbard Rd
Default I'm not buying it's me
Last PM (2/7/08) from 8:35PM till I went to bed at 10:30PM I could not access this site. I tried to remove cookies again I also tried removing temp files. Every other site I went to worked perfectly.
Old 02-08-2008, 08:19 AM   #16
wifi
wifi's Avatar
It would be interesting for us network types to look out to the website from your PC to see how you are routed.
*When you can't connect* run a traceroute and post the results (well, save it and post when you can connect....LOL).
In windows, start/run/cmd/tracert www.winnipesaukee.com
Linux: traceroute www.winnipesaukee.com
Mac: Got me
Here is what I see:
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\Documents and Settings\Wifi>tracert www.winnipesaukee.com
Tracing route to winnipesaukee.com [74.54.143.218]
over a maximum of 30 hops:
1 <10 ms <10 ms <10 ms 10.41.92.254
2 <10 ms <10 ms <10 ms 10.41.0.161
3 1 ms 1 ms 1 ms 10.41.0.129
4 33 ms 22 ms 42 ms 10.41.0.5
5 43 ms 34 ms 43 ms 12.147.122.161
6 70 ms 65 ms 50 ms 12.87.29.157
7 102 ms 94 ms 110 ms 12.127.5.94
8 97 ms 108 ms 98 ms cr1.cb1ma.ip.att.net [12.122.20.137]
9 112 ms 107 ms 117 ms cr2.n54ny.ip.att.net [12.122.31.125]
10 97 ms 112 ms 182 ms cr2.wswdc.ip.att.net [12.122.3.38]
11 128 ms 83 ms 98 ms tbr1.wswdc.ip.att.net [12.122.16.14]
12 116 ms 140 ms 112 ms tbr1.sl9mo.ip.att.net [12.122.10.30]
13 112 ms 122 ms 108 ms tbr2.dlstx.ip.att.net [12.122.10.90]
14 125 ms 121 ms 108 ms 12.122.100.109
15 165 ms 108 ms 108 ms 12.87.41.150
16 117 ms 95 ms 125 ms te9-2.dsr01.dllstx3.theplanet.com [70.87.253.14]
17 141 ms 100 ms 91 ms 7e.fd.5746.static.theplanet.com [70.87.253.126]
18 111 ms 99 ms 124 ms po2.car06.dllstx6.theplanet.com [12.96.160.40]
19 114 ms 93 ms 100 ms da.8f.364a.static.theplanet.com [74.54.143.218]
Trace complete.
Old 02-08-2008, 08:23 AM   #17
Old Hubbard Rd
Default Something is fishy??
I just checked all the forums from last PM (2/7/08) and noticed that between the hours of 8:35PM and 10:30PM there was only 1 post. All other post were either before this time or after?????????????????????????
Old 02-08-2008, 05:33 PM   #18
froggy
Default What browser?
I go on other forums for professional reasons.
One, powered by same, functions better with FireFox, and also the other is better on Firefox. However, this will not function in Firefox, on a Mac.
I need to use Safari, which works poorly with the other two.
What is experience of others? Thanks
froggy is offline   Reply With Quote
This page was generated in 0.16167 seconds
