Old 12-05-2006, 01:10 PM   #1
Default Broken 40hp Mercury
Took my 40hp Merc (2 stroke) for a last run before winterizing and noticed white smoke billowing out of the exhaust.It steadily lost power as I barely made it back to the dock before it died.It didn't run out of oil and still turns over but won't start. Nor looking for a fix by mail,just wondering if anyone had a similar problem so I'll know what to expect when I bring it in for repair. Thanks in advance.
Old 12-05-2006, 01:13 PM   #2
Woodsy
White smoke is an idicator of water in the combustion chamber. Sounds like a head gasket.... might need new pistons too. You can do a quick compression test to figure it out. A quick visual check would be to pull the spark plugs.
Woodsy
Old 12-05-2006, 06:14 PM   #3
Thanks much,Woodsy.That will be an easy test.
Old 12-05-2006, 10:20 PM   #4
secondcurve
Samiam:
I'm curious, what year is the motor?
Old 12-06-2006, 01:35 PM   #5
Right around 1998.....not exactly sure ,but it ran great up to that point...Might be trashed if the pistons got fried...Oh well
Old 12-07-2006, 06:44 AM   #6
secondcurve
Samiam:
That seems like a relatively new motor to have the type of problems you are describing. I'd be curious to hear what your mechanic says.
Old 12-07-2006, 10:33 AM   #7
I'll probably wait until spring to tow it down,but will definately post the diagnosis.Just wanted a few advance thoughts so I don't get ambushed.Thanks
This page was generated in 0.09350 seconds
