Old 04-28-2006, 04:54 PM   #1
Sunbeam lodge
Sunbeam lodge's Avatar
Default Grease Fittings on Mercruiser
Does anyone know how many and where the grease fittings are on a Bravo III
Merc Cruiser inboard/outboard engine. I could omly find 1.
Sunbeam lodge is offline   Reply With Quote
Old 04-29-2006, 10:50 AM   #2
chunt
That one fitting is used to grease the gimbal beariing. On some models, there is also a grease fitting inside the boat were the fdive shaft goes into the coupler. If you remove the drive, there is two fittings on the input shaft universals.
chunt is offline   Reply With Quote
Old 04-30-2006, 11:48 AM   #3
Pretty sure there are two fittings on the coupler. This is done just to increase the odds that you can access at least one of them regardless of where the crabkshaft stops when the igntion is cut. If you can't get a grease gun on either of them, bump the engine over for a split second to rotate the crank a little and try again.
This page was generated in 0.07313 seconds
