Old 01-23-2026, 01:52 PM   #1
puremaple
Default ECM no good
I was recently told that the ECM on my 2000 Mercruiser 7.4 mpi is no good. And to make matters worse it is no longer supported by Mercruiser... Has anyone had any luck with a remanufactured ECM?
puremaple is offline   Reply With Quote
Old 01-23-2026, 04:15 PM   #2
DesertDweller
https://obd2allinone.com/ecmrepair.asp
Name came from a boating forum I am on. Sounds like they can either repair your ECM (if possible) or sell you a remanufactured unit. Diagnostic fee is $80. Probably worth a shot.
puremaple (02-10-2026)
Old 01-24-2026, 08:06 AM   #3
Glad I have an engine with no ECM, just CDI. Extremely reliable.
Old 01-24-2026, 08:23 AM   #4
TomC
TomC's Avatar
A boat salvage place can probably hook you up. There was one in Meredith (M & M), but it doesn't look like they are there anymore (?). There are others in NH - here's one: www.kmsboatsalvage.com
The Following User Says Thank You to TomC For This Useful Post:
Old 01-24-2026, 08:55 AM   #5
In the past, Fay's has had a collection of salvaged parts.
Alan
The Following 2 Users Say Thank You to Slickcraft For This Useful Post:
LIforrelaxin (01-27-2026), puremaple (02-10-2026)
Old 01-24-2026, 01:30 PM   #6
Lakes Region Guy
What do ECM and CDI stand for?
Lakes Region Guy is offline   Reply With Quote
Old 01-24-2026, 02:55 PM   #7
TomC
TomC's Avatar
Engine Control Module & Capacitive Discharge Ignition
Old 01-27-2026, 03:58 PM   #8
Bootkie2
My first question would be how do you know for certain that it's your ECM that has gone sour?
Bootkie2 is offline   Reply With Quote
Old 01-27-2026, 07:23 PM   #9
DesertDweller
That would be my question as well. Getting it diagnosed for $80 might end up pointing you in a different direction.
Old 02-10-2026, 11:01 AM   #10
puremaple
Default Ecm
I dont have the write up in front of me but, I brought it in for not starting after stalling while out for a run... I thought it was old fuel so I did the fresh gas in a portable can with the primer ball to a new filter and was able to get it running for 15 seconds, then nothing after that.
They found good compression, and dry cylinders so they removed fuel rack and were able to determine that the injectors worked with ecm bypassed and concluding that the ecm was not giving the signal to the injectors.
Went to the boat show, so I will be looking forward to sending this out to be tested for 80 bucks.
Old 02-12-2026, 09:14 AM   #11
Question "Tuners"...
ECM "tuners" are everywhere for automotive ECMs--especially in racing applications.
If diagnostics indicate a faulty ECM, maybe give them a try:
ECU & Dyno Tuning Workshops in New Hampshire (NH) | Dynoseek USA https://share.google/N6L1XlFZcxsXUlinV
puremaple (02-26-2026)
Old 02-13-2026, 09:54 AM   #12
Bootkie2
ECU failure isn’t super common, and from how you described it, it sounds like the diagnosis may have taken a bit of a roundabout path with some mixed signals along the way. The easiest test probably would’ve been to bolt your ECU onto a known-good 7.4 and see if the stalling followed it. That would’ve confirmed things with a high level of certainty pretty quickly instead of sending you down the rabbit hole of ECU tuning and repair. Sounds like you are already down that path though so keep us posted and let us know how it works out!
The Following User Says Thank You to Bootkie2 For This Useful Post:
Old 04-23-2026, 10:55 AM   #13
puremaple
Update:
I found a guy in Virginia Maic Salazar diagnostics who confirmed the fuel injectors not getting the correct signal and repaired the ECM. Started right up!
This page was generated in 0.11847 seconds
