Thread Tools
Display Modes
does anyone have insight on mounting a trolling motor (specifically a Minn Kota with a quick release mount) on the bow of a pontoon? i am trying to figure out where to place the battery and how to run the wires.the bow door does not have a cut out.
TIA |
My 'toon has a lip around the deck. To avoid warping the mounting base, I added a couple washers under the bolt holes.
https://www.basspro.com/p/motorguide...rolling-motors Sorry, can't figure out how to upload the image. Keep looking though, there may be better options for you. |
The Following User Says Thank You to Kamper For This Useful Post: | ||
aquabones (06-04-2025) |
#3 | |
As far as batteries go, I had mine in a cooler on wheels with an outlet built in the side so I could take it in and off the boat. My Minn Kota was a 36 volt so it required 3 batteries. I didn’t like the added weight of three batteries in the front when cruising so would only roll it on when fishing. If you want to permanently mount them, under the front seat is the best place. Make sure you are using the proper gauge wire and fuse as your Minn Kota draws a LOT of amperage.. See pics below…. Good luck! Dan
#4 | |
Dan,
The things you do and the way you do them is always impressive to me! This is just another example. Right down to a spare fuse taped to the top of the cooler. Thanks for sharing! -John Quote:
The Following User Says Thank You to burgerunh For This Useful Post: | ||
ishoot308 (06-10-2025) |
looking for more advice on mounting my trolling motor on the pontoon boat. looking under there front deck, i can see that there is a piece of sheet metal that is underneath with about a half inch space between it and the undersurface.
my question is how can i get the mounting bolts and nuts set. do i just go through it all or is there another way. |
#6 | |
