Old 05-05-2025, 05:05 AM   #1
Default May 5: Water temp rises to 50-degrees
First time since late October, the Lake Winnipesaukee surface water temperature has gone above 50-degrees.
To swim the cold water, recommend a $60 O'Neill Thermo black t-shirt from Parafunalia in Gilford worn under a wet suit top. The tight fitting O'Neill Thermo gets soaking wet, long sleeve or short sleeve, but still holds in your core heat pretty good.
How does it work? I don't know, but it works.
This page was generated in 0.11515 seconds
