Old 08-19-2024, 09:32 PM   #1
4 for Boating
Default Trailer Tire Change
Hello - we have a small utility trailer that is in need of 2 new tires. (Old - dried out original tires have to go). So we acutally have the 2 new tires and are looking for a shop around the Meredith area that we can bring the 2 tires over to that will remove the old tires and install the new. (So, tires are already off the trailer.)
I ask as some bigger places are not interested in doing this sort of thing unless you buy the tires from them... Thanks!
4 for Boating is offline   Reply With Quote
Old 08-19-2024, 10:17 PM   #2
Is much easier and cheaper to buy two new trailer tires already mounted on new rims from the internet and replace them yourself.
None of the tire stores have a tire machine that will work with a small trailer tire. Is possible that one of the local motorcycle repairs could do it but it would probably end up costing double what you pay for two trailer tires on rims from eBay or Amazon.
Old 08-20-2024, 12:25 AM   #3
Question Maybe Bike- or Motorcycle- Shops...?
It's not an easy job, but you can do it yourself IF the tire is an 8" tire. You'll need steel tire "spoons", but they're not expensive. Harbor Freight should stock the few pieces of equipment you'll need.
If they are bigger than 8", try a used tire location. Before he moved north of town--and upscaled--we had a place that handled used tires right in downtown Wolfeboro!
When you're totally out of luck, you can buy new tires already mounted on new rims--economically, too--probably where you should have started...
Is it
"Common Sense" isn't.
Old 08-20-2024, 05:26 AM   #4
I'd call Clifford's in Moultonborough. Those guys are great.
Old 08-20-2024, 06:33 AM   #5
4 for Boating
Thanks for the thoughts. Note: The trailer came with 2 new tires so seems a shame to not use or discard them.
Old 08-20-2024, 06:42 AM   #6
Question They ARE 8-Inch Tires?
Contact your insurance company to learn who they recommend for roadside services. Or look up a "Roadside Service" business on the Internet. They've surely dealt with the problem of a trailer flat and can advise a solution.
Or advertise the new tires here at the Marketplace forum.
You'll get a thousand views and somebody (or two?) might want a spare (or two?).
Old 08-20-2024, 08:12 AM   #7
rick35
If the tires are old there's a good chance the rims won't hold a bead. I'd just buy three new tires and rims so you have a spare and then rotate one out when needed. Should run about $200 for three at Walmart or Amazon assuming they're the small ones. I saw a boat and trailer left on the side of 93 a couple of weeks back and the guy either didn't have a spare or had a bearing freeze up.
HTML code is Off
This page was generated in 0.23959 seconds
