Old 07-12-2024, 09:36 AM   #1
Winnielove
Default Condo Ins coverages
What is the typical condo doc coverage ie. studs in/studs out?
Hearing many companies write all in vs unit owners perimeter walls in,
very confusing.
Any experience with this?
Thanks in advance!
Winnielove is offline   Reply With Quote
Old 07-12-2024, 01:30 PM   #2
gillygirl
very confusing.
Thanks in advance!
It would probably depend on how the association covenants are written, assuming there’s an HOA/COA involved. My experience is only with Florida, but the COA I worked for, the homeowners were responsible from the surface of the drywall inward. Several buildings experienced water intrusion during hurricane Ian, some through the roof and some through the exterior wall. The COA had to foot the bill, and I, as the property manager, had to coordinate the repairs. However, if one unit leaked into another unit, then it was the responsibility of the homeowner causing the damage to coordinate with the owners of the unit that was damaged.
Not sure if that helps at all. You really need to delve into all of the governing docs for the property. And make sure the different documents don’t conflict. I had a rules and regs document that conflicted with the bylaws. Not sure they ever fixed that after I left.
GG
Winnielove (07-15-2024)
Old 07-12-2024, 03:14 PM   #3
GG is right. Each state and each HOA can be a little different. Before retiring, I sold insurance in NH, MA, ME and FL. Florida, in particular was a major mish-mash, and it's even worse since the collapse of that building in Miami a few years ago.
Developers tend to go cheap to keep condo fees down while they're trying to sell new construction. Once they move on, the new association may have changes and do some catching up on cash reserves. Any documents you use, be absolutely sure they are current, not last year's.
Your local attorney, realtor and insurer should all have some experience so you don't have to retrace other's steps.
This page was generated in 0.06613 seconds
