Old 06-21-2024, 10:04 AM   #1
Default Trailer Hitch
Crazy question.....
Taking a long trip (1000 miles), and pulling my loaded Cargo trailer.
Should I apply Lube to the hitch ball ? Is that needed or help ?
TIA
Old 06-21-2024, 10:10 AM   #2
Yes- there is specific lube for that but any good grease is better than nothing!
bigdog (06-21-2024)
Old 06-21-2024, 11:02 AM   #3
Default Ground?
On older trailers, the lights may use the car as an electrical ground, connecting through the ball/hitch.
Old 06-21-2024, 05:19 PM   #4
Blaster Dry Graphite lubricant or WD-40 Specialist Dry Lube with PTFE. Price for either one is about $7.98.
Both are dry, a lot cleaner than grease, color-black, sticky to remain in place and will conduct electricity.
Note: Blaster Dry Graphite lubricant is black and a very different product than Blaster Dry Lube which is white, greasy and more liquid.
Old 06-21-2024, 06:29 PM   #5
Loub52
Loub52's Avatar
Silicone spray works really well
Thanks,
Loub52
Old 07-12-2024, 08:18 AM   #6
NIOMARVIN83
When shopping for a truck, it's crucial to pay attention to the gear ratios. If you're planning to pull a boat or any heavy load, make sure to check the manufacturer's specifications and consider a truck with a lower gear ratio like 3.73 or 4.10, which are better suited for towing. Sacrificing fuel efficiency for towing capability is a common trade-off, so it's essential to find the right balance for your needs. Always be informed and choose wisely! This is what I did for my kenworth truck years ago.
NIOMARVIN83 is offline   Reply With Quote
HTML code is Off
This page was generated in 0.28192 seconds
