I’m looking for a float charger/maintainer for my boat batteries. I keep them in a friend’s heated garage several towns over so it is a pain to go over there every several weeks to check them.
Every time I find one and read the reviews they are usually something to the effect of, “after leaving my battery on it over the winter my battery was dead flat.” Or, “a piece of junk. Don’t waste your money.” Anybody use one of these that they can recommend? Sent from my iPhone using Winnipesaukee Forum mobile app |
#2 | |
https://www.batterytender.com/weather-resistant-800 I like it because it is water resistant and I can use it most anywhere inside or out. I keep a couple in my boat attached to the batteries with an SAE quick disconnect. My batteries last for years! Dan
jbolty (12-12-2023) | ||
Dan is correct!
I have 3 of them…one is a solar charger on my shed that trickle charges my ZT BATTERY and have 2 on my wife’s ‘55 ford Fairlane which occupies her old garage space. The ‘55 has one 6v and one 12v battery. (Starter booster.) Back when I had Harleys they all had a Battery Tender brand charger on them in winter storage. Walmart has a decent selection of them for different sized machines. |
#4 | |
https://www.batterytender.com/junior This particular model is not water resistant, but I only use them indoors. Battery Tender models are fully automatic, use four charging stages, and cannot overcharge a battery. I have used them for years on a lawn tractor, compact utility tractor, boats, and motorcycle and have never had a dead battery in the spring.
DRH |
What is not needed is a trickle charger. these never stop charging, which is not good for a battery long term, great for short term. A battery minder is called for. These charge the battery until charged and then stop until needed again.
I have two of these on my car presently, one for the starting battery and one r the accessory. Then all will be good to go when I return. The battery on my John Deere is not on a charger as I have found it really is not necessary, I put the trickle charger on for a short while when returning. I am a retired workaholic and continuing aquaholic |
I also use only the "battery tender" line of chargers.
Have tried others with terrible luck. One for each battery lined up on a wooden board off the floor. |
Battery Tender brand all the way. I’ve used them on motorcycles and garden tractors and gotten many extra years of life out of my batteries. I have two of them, and one is pushing 20 years and still working just fine.
NHskier |
+1 for Battery Tender. I bought one some years back after having to replace a series of lawn tractor batteries, and now I'm getting 4-5 years out of them.
Sent from my SM-S911U using Tapatalk |
What I do is I buy their ring terminal pig tails and attach them to all my toys batteries... boats, snowmobiles, Atv's, lawn mower, snowblower, etc, etc. then its just a simple quick connect to the battery tender when needed.
https://www.amazon.com/Battery-Tende...1zcF9hdGY&th=1 Dan
Hillcountry (12-13-2023) | ||
The ring terminal approach ishoot mentioned definitely makes it easier than the small alligator clips. You can have that pintail exposed so no need to get under a hood or maneuver to get to battery terminals. You can also get extension cables if needed.
NHskier |
#12 | |
Hey ....... snowblowers do not have batteries ........ you attach an extension cord to the electric start motor or just pull on the pull-start handle. Have never seen a snowblower with a battery?
According to Wikipedia, there is not a single snowblower in the world history of snowblowers, ever made, that has a battery! Not even the most expensive Ariens has a battery. .....
What about solar options, what do people like, I have older model ones on my boats, but last year I noticed they were struggling, so I was looking for reccomendations on ones I can leave on the boat when at dock or sand bar. U usually put one out on the swim platform while it sits, and small fishing boat I like one on the starter battery as well another on the deep cycle for the accessories and trolling motor. anything out there that does two batteries at once for that type of application?
Capt. of the "No Worries" |
#15 | |
If you go over a 10 watt panel, I would recommend you also get their solar controller to keep your batteries from over charging. https://www.batterytender.com/solar-...ater-Resistant Dan
Thanks again for the input. I picked up a Battery Tender plus. I don’t use during the season as the batteries seem to keep charged from boat use. My need is over the winter while the batteries are in storage. Thanks for the input one more time.
