Old 10-01-2022, 08:38 AM   #1
bobkatfly
bobkatfly's Avatar
Default Replacement trailer winch strap
Just noticed my winch strap is a bit frayed at the hook end. Mostly UV exposure. The winch itself is fine. Any recommendations on a decent strap replacement? From what I've seen polyester is the go-to for strength and minimum stretch. Also, a forged hook would be nice but maybe not essential.
Strap is standard 2" x 20 ft and boat is typical 21 ft bowrider ~4000 lb. Shoreline, Rhino, Fulton, Boat Buckle, others????
Bob F
Old 10-01-2022, 09:07 AM   #2
A note: I bought a couple new ones off Amazon that are really nice, BUT they're "heavy-duty," which means they're thicker than what was on there and, to use them, I had to cut them way down because the bolt on the arm that holds the winch was cutting into them.
Old 10-01-2022, 09:20 AM   #3
The Real BigGuy
I would stick with polyester. It is soft, strong, doesn’t stretch, and doesn’t absorb water. Because a boat is considered a rolling load and you probably have bunkie boards or rollers on your trailer you only need a strap rated for 2,000/2,500 lbs. That said, when replaced the strap on my 4,000 lb boat I put a 10,000 lb strap on. It was cheap in the overall cost of boating and it just made me feel a lot more comfortable. I don’t remember the brand but I got it on Amazon. It had the most & highest ratings compared to others.
bobkatfly (10-01-2022)
Old 10-01-2022, 11:59 AM   #4
bobkatfly
bobkatfly's Avatar
Curious, how did you cut them down? Did you cut off the winch end loop and re-stitch?
Bob F
Old 10-01-2022, 12:21 PM   #5
I cut the loop at the end that wraps around the bolt on the inside and sewed a new loop.
Old 10-01-2022, 03:08 PM   #6
bobkatfly
bobkatfly's Avatar
Ended up with Rod Saver brand at Amazon. Spent too much time thinking about it. Too many choices. 16 footer instead of 20 but not important for what I do. When I unwrapped the old one I think about 15 feet of it looked new. Should have brought it to Think to do his seamstress magic on it.
Bob F
Old 10-01-2022, 03:22 PM   #7
I assure you it is not seamstress level quality, but it works!
Old 10-02-2022, 10:39 AM   #8
You can just cut the worn end off and tie a bowline knot in the strap to attach the hook.
The Following 2 Users Say Thank You to Dave R For This Useful Post:
ApS (10-02-2022), bobkatfly (10-03-2022)
Old 10-03-2022, 04:52 PM   #9
bobkatfly
bobkatfly's Avatar
Thanks Dave. That would definitely work in a pinch if needed. Ratchet straps that I keep in the truck would also take care of it till I got home if it did break while loading.
New one is inexpensive and already purchased.
Bob F
Old 10-04-2022, 03:55 PM   #10
I'm late to the party on this one, but I usually look to Harbor Freight or Tractor supply for things like this. Glad you found something.
This page was generated in 0.35992 seconds
