Old 04-11-2022, 08:10 PM   #1
eillac@dow
eillac@dow's Avatar
Default Composite Decking
Does anybody know if you can paint composite decking?
If so, has anybody done it? And what product did you use?
The decking I have is about 15 years old. I regretted the color of the decking as soon as it was put down. It would be nice to be able to change color.
Thanks for any information you may have.
eillac@dow is offline   Reply With Quote
Old 04-11-2022, 09:22 PM   #2
secondcurve
Hi:
Google rustoleum rocksolid composite deck refresh. I haven’t tried it but it might be what you are looking for.
ABOUT COMPOSITE DECK REFRESH
RockSolid® Composite Deck Refresh Toner is an exceptional water-base exterior toner designed to refresh the color and restore the finish on faded composite wood decks. It provides protection against water damage, UV graying and mildew. It is easy to use, dries fast and cleans up quickly with water.
One coat application
Protects against UV damage
Resists Mold & Mildew growth
Provides superior water repellency with hydrophobic Properties
Covers up to 300 sq. ft.
FOR BEST RESULTS
Be sure to choose the tone that best matches the original composite deck color.
AVAILABLE SIZES
1 Gallon
FIND
Good
The Following User Says Thank You to secondcurve For This Useful Post:
eillac@dow (04-13-2022)
Old 04-12-2022, 11:45 AM   #3
John Mercier
Which composite?
Early forms of Trex could be... current forms cannot be.
Old 04-13-2022, 05:35 AM   #4
eillac@dow
eillac@dow's Avatar
Thank you John and Secondcurve for your responses.
I’m not really sure what type of composite decking it is. Not even sure if we have the paperwork from when we purchased it. I’ll have to check.
Thank you very much for the information that you provided on the RockSolid It sounds good but it does say you should probably stay as close to the original color as possible. Unfortunately The color I have a similar to a brick color and I was looking to maybe change the color to something in the gray family.
Appreciate your thoughts and comments.
The Following User Says Thank You to eillac@dow For This Useful Post:
secondcurve (04-16-2022)
Old 04-13-2022, 07:50 AM   #5
When we had that (which I hated) we bleached it. It won't change your color but at least it will get some -SOME- of the mold out.
eillac@dow (04-18-2022)
Old 04-13-2022, 09:28 PM   #6
John Mercier
Mold shouldn't be able to attach itself to a capped composite... and bleach will weaken the plastic binding material that is the major component of the board.
Old 04-14-2022, 08:01 AM   #7
Well, we certainly had it, but then again mold can attach it self to anything. Maybe the bleach did weaken it but at least it looked better.
Old 04-14-2022, 09:33 AM   #8
How many square feet are you talking about? I think that you will be constantly chasing/maintaining it if you try to paint composite. Its not a material that was meant to be painted. I would look to replace it with something new, in the color you want.
Old 04-14-2022, 06:31 PM   #9
John Mercier
The mold actually eats the pollen/dirt that is caught in the tread pattern of the decking. It will also do the same thing to vinyl siding.
It turns black when it runs out of organic matter to consumer or dries due to a lack of moisture.
The manufacturer suggestion is to wash the deck twice per year... once to remove pollen... the second to remove leaves/etc.
Spots/areas that are not responding to just hose pressure should be brushed with a soft bristle, and then rinsed.
The ''wash'' may be no more than rinsing off with the hose if no areas of concern are noted.
That process also creates the situation where the owner will inspect the deck twice per year and note any situation that might need a repair.
Old 04-14-2022, 06:44 PM   #10
I washed it more than twice a year. Anyway, I don't have it any more. I think I have had every kind of decking imaginable starting with PT and was never happy with anything until the Azek which I currently have. This is the least work and after quite a few years still looks pretty good.
Old 04-14-2022, 07:16 PM   #11
John Mercier
The Azek should be washed twice a year also. Though mold cannot eat it either, mold will appear whenever spores and moisture present the condition for the mold to grow then die.
Azek will scratch easier than a composite... and care needs to be taken on certain products - things like sunscreen/lotion - getting on its surface.
But like a composite deck, using a shovel with a plastic edge... and keeping it clean should avoid most of the negatives.
Its greatest use was as a dock material. Very light - more like cedar - compared to PT or composite options. They even make a new version called MAX that can handle a two foot on center substructure here in New England.
And due to width options (4/6/8), it can make a very dramatic statement without a lot of additional cost.
Old 04-15-2022, 07:51 AM   #12
This is pretty old and I have it on all docks and decks and IMO it is the easiest to care for of all the ones I have had. It looks the best and is not as hot on your feet as some. I do wash it quite often -certainly more than twice a year -because I like things clean but love that it never needs to be sanded or refinished or anything like that.
Old 04-15-2022, 06:03 PM   #13
John Mercier
Depending on the line of Azek, the color should go all the way through.
The maintenance for composite/PVC is roughly the same... wash and inspect.
The products should last a lifetime... or in Azek PVC's case several lifetimes.
The inspection is mostly due to issues that might arise with the substructure.
Old 04-16-2022, 10:40 AM   #14
RUGMAN
Has anybody used Endeck pac decking?
Old 04-16-2022, 01:25 PM   #15
John Mercier
Sorry, I have never heard of that name locally.
Is like Azek or ZURI?
Old 04-16-2022, 02:27 PM   #16
RUGMAN
Sorry, PVC. out of Florida
Old 04-16-2022, 02:42 PM   #17
John Mercier
AZEK and ZURI are both PVC.
ZURI has a PVC core with a laminated photo-realistic print and then top coated with a hard layer of acrylic to resist scratching.
My guess is that Endeck is possibly like the ZURI.
Old 04-16-2022, 04:27 PM   #18
bobkatfly
Default Back to painting
Our house has a composite board deck from the '90s. Not sure what brand as it was installed by the previous owner. My wife went at it with Behr solid deck stain. She cleaned thoroughly then two coats. Although I hate the color (battleship gray). It has held up since then. Has no roof over it and gets full southern sun. I have been quite surprised.
Bob F
The Following User Says Thank You to bobkatfly For This Useful Post:
Old 04-16-2022, 06:43 PM   #19
John Mercier
The 90s most probably was Trex Generation 1.
That composite was uncapped, and expected to be stained.
Trex has problems selling it, as it required the same maintenance as PT/Cedar decking but at a premium price.
I've seen it on some older decks, but can no longer get that product.
This page was generated in 0.10125 seconds
