Just drained and refilled my Merc 4.3L sterndrive.
I bought 1 qt of Mercury SAE-90, but it was not enough. I can see this in the engine reservoir container, that it is about 4-6 oz, below the full line. SAE90 is not cheap at $16 a quart. Question..... I have some 85W x 90 drive oil I used last year for a Outboard, can I add this to the current straight SAE-90, without causing any issues ? I'd buy another quart of SAE90 to add, but I'll be selling the boat in the Spring. Thoughts? |
'The wrong oil is better than no oil'
Walmart.com says the Gilford Walmart has quarts of Quiksilver high performance sae-90 gear lube for $9.97/qt ..... and probably has Super Tech 80w-90sae marine gear lube for $6.28 .... and the out-drive will never know the difference!
5-stars, 10/20/2019: "Good price and I like the color of the oil (SuperTech). Easy to see if you have any water in your oil." ..... BigDaddy
I dont mix different weights. I dont even like mixing same weights of different brands. Buy the other quart at $16 and save the remainder for next year..............
| The Following User Says Thank You to SAB1 For This Useful Post: | ||
DotRat (09-30-2021) | ||
Just to repeat... 'I'll be selling the boat in the Spring'.
Only need about 6oz to fill reservoir to full level. Thanks ! Last edited by bigdog; 09-30-2021 at 05:18 PM. Reason: spell |
It's $16 to do it right. Add it to the price when you sell it.
Sent from my SM-G950U using Tapatalk |
What would you do if you were keeping the boat? Do the same for the next guy. Its $16, Jeez… I put a set of tires on a car once for my buyer. $16? Do you squeak when you walk? ![]() BTW, thank you for the referral, Kevin! Sent from my iPhone using Tapatalk |
$16 is the price of a 4 pack of micro brewed beer. Why screw the next guy. I’d be embarrassed to say that.
