Old 08-11-2021, 11:04 AM   #1
Default Oil change problem ?
I just went to change my oil in my 4.3L MerCruiser engine.....
I've done this before using a hand pump I purchased at boat supply store.
The pump has an inlet hole where you connect a plastic tube, the other end over the dipstick (yes I removed the dipstick). The other inlet hole you connect another plastic hose, where the pumped oil will come out.
The issue is, when I start pumping, no oil comes out, it's like there's something wrong with the pump ? I've only used this pump 'one' time, in the past, so confused ?
As an alternative solution, is there an electric pump or a pump that can be attached to my electric drill to pump out the oil ?
Thanks for you comments, much appreciated !
Old 08-11-2021, 12:02 PM   #2
I bought one of these about six years ago. It makes everything so easy and cleanup is quick. I use it on the boat, jetski, lawnmower and snowblower….
https://www.amazon.com/Jabsco-17850-.../dp/B001CX0WX4
Old 08-11-2021, 12:08 PM   #3
Woodsy
If its something like this, you need to make sure all the connections are tight and its not leaking vacuum anywhere. I have had mine for years and it works mint!
https://www.amazon.com/Mityvac-Fluid...701622&sr=8-56
Woodsy
Cal Coon (08-13-2021)
Old 08-11-2021, 12:35 PM   #4
Default air leak?
It sounds like an air leak someplace. Perhaps a split in the plastic tubes?
Old 08-11-2021, 01:03 PM   #5
You may have lost the washer that goes in the female screw on fitting.
Also, these work best with “run around the lake” hot oil, not “let it idle for a while at the dock” warm oil.
Old 08-12-2021, 07:26 AM   #6
Default Old school.
I fitted a rubber hose to the drain plug on the oil pan. The rubber is long enough to attach to the transom. If the boat is out of the water, I would run the hose through the drain in the transom and remove the oil. If the boat is in the water I would fit the hose to a drain pump. Pretty slick!
This page was generated in 0.26411 seconds
