07-11-2021, 05:42 PM | #1 |
Ants ! HELP !
I have ants in the house, isolated to the kitchen. The medium/large black ants.
I've tried ant bait traps, sprays, and they keep surfacing. The kitchen floors, counters, are all clean. No food is left out on counters. They keep appearing on the floor, near the sink and fridge. Any suggestions will be appreciated, thanks ! |
07-11-2021, 06:09 PM | #2 |
Not sure what traps you've used, but I've used those clear liquid Terro baits a few times, and they've been ridiculously effective. If you've not used those, I'd give 'em a go. Otherwise, JP Pest.
Sent from my SM-G950U using Tapatalk |
07-11-2021, 06:32 PM | #3 |
We use JP Pest for all our pest problems now. I use to take care of it myself but if my wife saw 1 mouse, 1 ant, or 1 bat, I got an ear full.
Now she calls JP pest and gives them an ear full. Best money ever spent! |
07-11-2021, 06:33 PM | #4 |
We had lots of black ants inside the house last year and it drove my wife (and me as a consequence) NUTS. We tried all the recommended items...Terro, etc., but they kept coming. I swore I would hire someone this spring. I hooked up with Steve from Presidential Pest Control. 603-723-7250. Steve arrived in April...sprayed the entire outside of the house and said there may be a few that escape, but if we see a lot of them again, he would come back and re-treat the place for free. Well, here we are and I must admit, we have seen ZERO ants. None...Not one. Treatment was 1000% effective. We made arrangements for him to come automatically every spring and do an annual treatment. IMHO,
I would not fool around with these consumer products...call the professionals and be glad you did. Last edited by tummyman; 07-11-2021 at 06:36 PM. Reason: clarifying word added |
The Following User Says Thank You to tummyman For This Useful Post: | ||
DotRat (07-12-2021) |
07-11-2021, 06:38 PM | #5 |
Same problem this year.
I stalled putting the TERRO out until I saw them inside the house. Of course, by the time you see them they are in full forage mode. I have the TERRO liquid bait inside, outside, diatomaceous earth, and now some ant spray for what appears to be carpenter ants attacking the garage. Since we just had some trees taken down... I suspect that we may have disturbed a nest, and will have to attack the colony with the baits. |
07-11-2021, 06:50 PM | #6 |
Terro liquid traps solved our problem in a day.
07-11-2021, 07:51 PM | #7 |
The large carpenter ants like wet wood. Look for wet wood, fix the issue that causes it to be wet, and that will help with your problem.
I have used the Terro bait traps several times and had great success. However, every year there seem to be ants, no matter what you do. I have had good success with "Home Defense" that I buy at Lowe's. It works on a lot of insects including spiders. |
07-11-2021, 08:12 PM | #8 |
I used a bug barrier spray along my foundation and bug bombed my ceiling spaces where they were spotted... A gazillion of them came out and I vacuumed them up.
Gary ~~~~_/) ~~~ ~~~~~~~~ |
The Following User Says Thank You to garysanfran For This Useful Post: | ||
07-11-2021, 08:30 PM | #9 |
This and the gel bait. Works great and if you want you can also buy a spray to do the perimeter. I got this directly from a professional pest company owner. This is what they use and you can't find it in your local stores. Make sure you use something that the ants bring back to their home, because if you only spray the perimeter it won't kill them they'll only move.
https://www.domyown.com/advance-375a...bait-p-39.html |
07-11-2021, 08:38 PM | #10 | |
The Following User Says Thank You to bigdog For This Useful Post: | ||
07-11-2021, 09:20 PM | #11 |
Tough to get a pro out to an island. Terro works pretty good. We nevedr had problems when my father spread garden lime around the perimeter. It worked so well, we stopped. A few years later, the ants came back. I vote for the heavy duty treatments noted above, lime later on.
07-11-2021, 11:58 PM | #12 |
I surround the house against the foundation with these outdoor traps. And it has worked for years.
I buy like 5-6 boxes and put one about every 4ft around the entire house. Called Amdro Bait Stakes. I also put a just few in the kitchen. Like under the stove, fridge, under sink. Where our dogs cant’t reach them. I get them at Home Depot. They are cheap. https://www.homedepot.com/p/AMDRO-An...973438#overlay |
The Following User Says Thank You to mswlogo For This Useful Post: | ||
07-12-2021, 12:57 AM | #13 |
I have used Home Defense for years, maybe decades twice yearly. Sprayed in the basement along the exterior joists and the floor. Sprayed outside along the foundation and window sills. We have brick facing so I spray a little way up the brick at adjoining walls. Maybe see one or two ants in the house yearly if that.
Several years there were termites along the driveway and since using Home Defense we have not seen any. There is a tree with an ant problem and I used Grants ant and termite liquid on that, under control but not eliminated. _________________________________ I am a retired workaholic and continuing aquaholic |
07-12-2021, 05:46 AM | #14 |
Ant nest
Ants are a yearly thing here - although this year, we discovered Turro and as others have said, it works great. It is basically Borax, so not as toxic to animals or babies as other stuff might be. The big ants were a big problem here a few years ago and we suspected a rotten floor of a porch to be the issue. Sure enough, after pulling up the porch boards, we found the motherload of ant eggs. The shopvac and a healthy dose of unhealthy pesticides took care of the problem. Without finding the source, I don't know that anything would have worked.
-lg |
07-12-2021, 06:54 AM | #15 |
I basically do what Woody38 said every year right about Memorial Day weekend. If you make that an annual event you won’t have an issue. The Ortho Home Defense is fine. The Spectacide Ant Shield at the Home Depot is very good as well. Like said above carpenter ants love wet wood. You need to find it and spray it good then spray around your entire foundation from the ground 18 inches up.
secondcurve (07-16-2021) |
07-12-2021, 07:39 AM | #16 |
Mix sugar and Borax together, sprinkle around, ants love the sugar, eat it mixed with borax and DIE. good for environment
07-12-2021, 08:08 AM | #17 | |
Given the OP's description of the problem, I'd be surprised if his problem isn't gone in a day or two with the ~$5 Terros. Sent from my SM-G950U using Tapatalk |
07-12-2021, 09:18 AM | #18 |
I'd first suggest the OP find out what kind of ants he has. Agreed, Terro works great for the ants looking for sweets/food. But if he has carpenter ants or the like, Terro won't do any good and he needs to find the bigger problem of where the rot is that's attracting the ants.
07-12-2021, 06:57 PM | #19 | |
07-12-2021, 08:09 PM | #20 |
Just purchased Terro traps today, and placed around the kitchen in corners,
under island, and under sink. Now to wait and see if they work....TBD |
07-21-2021, 10:31 AM | #21 |
I have a simpler suggestion: cinnamon. Ants hate it. I've used cinnamon successfully against ants many times. It takes a fairly large quantity and you have to leave it in place until they decide not to return. It should be placed along a line where they enter. They won't cross the line to "get to the other side." See https://lasvegas.rentokil.com/blog/6...-get-rid-ants/ Mice aren't fond of cinnamon either.
07-21-2021, 11:22 AM | #22 |
07-21-2021, 01:17 PM | #23 |
07-26-2021, 07:14 AM | #24 |
2nd vote for Steve/Presidential pest!
We are on an island and did a lot of diy pest control - but the year we found a carpenter ant nest in the house we changed to using a professional and it has made a world of difference. He comes every spring and as stated above promises to return if we are still having problems....but has never had to come back! So worth it to us.
