Old 10-04-2020, 02:19 PM   #1
V8TOR
Default Meredith Ramp
Has anyone used the Meredith ramp lately? Have a 195 Crownline was thinking of day launching next weekend and was wondering if it’s still deep enough. Used it in October 2016 where we had to balance the rear wheels half way off the slab to make it work.
V8TOR is offline   Reply With Quote
Old 10-05-2020, 09:56 AM   #2
I would launch elsewhere, it's really bad!
If you have a roller trailer it might be ok but I don't think you could get in deep enough with a bunk trailer.
Old 10-05-2020, 11:03 AM   #3
Center Harbor is likely ok.... Up in moutonborogh the F&G access at the end of Long Island, States landing, and Lee's Mills are all likely still viable.....
V8TOR (10-05-2020)
Old 10-05-2020, 10:14 PM   #4
V8TOR
Thanks, I’ll try Center Harbor.
Old 10-06-2020, 06:51 AM   #5
Bud63
I pulled my 27' R7 out of the water at Meredith on Sunday and had no issue with getting the bunk trailer deep enough
Bud63 is offline   Reply With Quote
The Following User Says Thank You to Bud63 For This Useful Post:
Biggd (10-06-2020)
Old 10-06-2020, 08:40 AM   #6
Did you have a double axle trailer and hang the rear wheels off the edge of the last cement section of ramp? If you have a single axle trailer and the wheels go off the ramp you're in trouble.
There are a couple wooden posts sticking up at the end of the cement ramp sections. When I looked at them this past weekend one recently had the top chewed up by a prop.
Top-Water (10-06-2020)
Old 10-06-2020, 08:18 PM   #7
Flotnjr
I haven't used the Meredith ramp in years, but the Center Harbor ramp has always been very deep and accessible. Plus you can pull off to the side and close up your boat and put your straps on without blocking traffic!
Flotnjr is offline   Reply With Quote
Old 10-07-2020, 12:01 PM   #8
Bud63
I have a double axle and the rear axle was off the concrete but it was no biggie to pull it out with my GLS 450
Old 10-07-2020, 01:21 PM   #9
V8TOR
Thanks Everyone. I have a single axel so perhaps Center Harbor is safer. I suppose I could always try Meredith first. It’s on the way. This is a sort of ritual I do at the beginning and end of each season. It’s on Winnisquam full time.
Old 10-07-2020, 05:09 PM   #10
There is the key, you where able to keep one axle on the pad.... There are a few ramps that just end out in deep water like that on winnipesaukee. Unfortunately they cause a major issue if you have single axle trailer. Coming from the west coast I am very familiar with this issue. Once a single axle goes over the edge, it then rests on the trailer frame on the edge of the ramp.... Friction is a bitch with the boat then loaded.
A few of the places I boated out west in drought years, you actually stopped using the ramp, and a section of the beach on the lakes or rivers would be opened up to facilitate launching and retrieving of boats.
The best solution to this situation can be seen at Winnisquam Marine, where they attached metal plates to the end of the ramp, so that they can back further in, during low water periods... although they have limitations as well.
last I knew Melvin Village Marina, was going to install a similar solution to their ramp, because they where having continuing problems with low water and their ramp.
Biggd (10-07-2020)
Old 10-09-2020, 07:57 PM   #11
TomKat
Default Center Harbor
Pulled out of Center Harbor yesterday
It was plenty deep for for my 23' onto a tandem axle.
TomKat is offline   Reply With Quote
This page was generated in 0.15362 seconds
