Old 06-22-2020, 11:48 AM   #1
Closetzguy
Default Spray foam Insulation company?
Would anyone be able to recommend an insulation company for our Tuftonboro home? Thinking of spray forming the underside of our roof.......which is our "vaulted ceiling" then putting new v-grove material across the 4x8 beams. It was a bit hot up there this weekend! Thank you.
Closetzguy is offline   Reply With Quote
Old 06-22-2020, 07:19 PM   #2
Winnigirl5
Default Spray foam Insulation recommendation
Best spray foam insulation company in lakes region is Weathertight Spray Foam. Owner operated so you know you will get the best job. Call them at 603-494-5490.
Winnigirl5 is offline   Reply With Quote
The Following User Says Thank You to Winnigirl5 For This Useful Post:
Closetzguy (06-24-2020)
Old 06-23-2020, 08:41 PM   #3
Billy Bob
Why should we assume that owner operated has something to do with someone providing the best job ?
Billy Bob is offline   Reply With Quote
Old 06-23-2020, 09:24 PM   #4
Loub52
Loub52's Avatar
Quality Insulation did a nice job with spray foam insulation on the underside of a screen porch at our home in Meredith. Not sure whether they service Tuftonboro, but worth a quote.
https://www.truteam.com/branches/nh/...tion-meredith/
Thanks,
Loub52
The Following User Says Thank You to Loub52 For This Useful Post:
Old 06-25-2020, 02:31 PM   #5
Arabella
Arabella's Avatar
Default Spray Foam
We used Superior out of Ossipee, they were great. Ended up doing it differently than what I was thinking originally, but they steered me in a better direction.
Arabella is offline   Reply With Quote
Old 06-25-2020, 03:58 PM   #6
An owner usually has more incentive to do a good job than the just the hired help, esp if he wants good references.
This page was generated in 0.13367 seconds
