I am aware of a lot of the pros and cons of both types of trailers, however, I would be interested to see if there are some things that I can learn about either type, with some suggestions from others that have had their own experiences with them, good or bad. I am conducting an informal, (personal) survey!
I have had both.
I prefer bunk trailers but depending on the ramps you use sometimes a roller trailer is the way to go. Bunk--Less maintenance, supports boat better, easier to center boat Roller--Good for short ramps, shallow water I grew up boating in New Jersey and a lot of the ramps we used you pretty much had to have a roller trailer depending on the tides. For the ramps I use on Winnipesaukee (primarily Center Harbor), a bunk trailer is the way to go. |
For many of the reasons listed above I prefer bunk trailers as well.
Maybe its just me but when ever I see a trailer at the ramp with just rollers, I just kinda know its going to take a while for them to get it loaded back up. |
I’ve had rollers pretty much all my life. The key to loading the boat on them is to spend the time when you buy a boat to set the bunks up to match the hull. At the ramp I’m on the trailer (drive right on) just as fast any bunk trailer. I don’t dislike bunks though. They work great. I’m a deep v Proline so rollers work better especially in fall when the waters low. Don’t think I’d ever get the bunks in deep enough for the boat and you have to crank it on the trailer rollers are your friend.
I agree, It really depends on the ramp. Bunks work well on a steep ramp but if you have a shallow ramp you really have to back in pretty far. I don't really like the water going over the back wheels of my truck, esp salt water.
I had rollers but I installed side bunks and vertical guide-ons. I boated in rivers a lot and the bunks acted as a cradle to keep the boat in place against a current.
Never owned a roller trailer and if I ever did buy a boat with one I'd get rid of it. I don't like them for a myriad of reasons.
Three reasons why I personally prefer bunks: #1 Excellent support of the boat where the weight of the boat is distributed across the surface area of the bunk(s). Easy to fix, replace or modify too. So swapping to 6" bunks, making them longer etc... easy to do. Rollers are just to overly complicated. #2 Easy to load - they are almost idiot proof to load a boat on and will self correct minor mistakes in approach. I did say almost, there are those that manage to screw this up to which I just say there is no helping them. #3 Boat is on a much LOWER center of gravity while sitting on the trailer. This is nice for towing. Rollers trailers place the boat way high on the trailer which I really don't like. I want the boat as low and snug to the trailer as possible, less wind resistance and better visibility while in tow. Everyone has their opinions I guess. |
#8 | |
Recommend Bunk Only.
#11 | |
The bunks should catch the boat flat on the bottom not on the chines. I doubt it would hurt the boat per say but not ideal as you don't want the gel coat on the leading edge to crack with the full weight of the boat on it. Take a look at your trailer again and see if the bunks can be adjusted wider or narrower in relation to the trailer itself. Usually they can be. Trailers are typically made to be adjusted in some form unless it's some sort of specialized application. I'd be careful in using narrower bunks - might be worth having somebody who knows this stuff to have a look and advise you as to the best course of action.
Far as your needing to put the trailer deeper into the water, not sure about that. I have found that with all the trailers I've had sinking them to where the top of the fenders are just at the water surface is the sweet spot, just approach the trailer slowly, aim for the center drift the boat in and let it settle itself, trim up a bit give it a little bump of the throttle (should not take much at all) to get it started up the bunks and 99% you're perfectly centered. Crank it up the rest of the way and you're good. There is no need to "power load" like many do. |
| The Following 2 Users Say Thank You to MAXUM For This Useful Post: | ||
Top-Water (09-02-2019), upthesaukee (09-02-2019) | ||
I have a bunk trailer with my 99 FW SD 245. The trailer is also FW and matched to the boat. Was going to swap for rollers at one point thinking they may be a better system. I did not and glad I did not after doing lots of comparisons. As pointed out bunks are easy to maintain and replace if necessary.
#14 | |
#15 | |
Perfect ........ you can't do any better than that. Very well defined. Agreed, most of the problems I have seen seem to come from going in to deep from the start. |
All of my trailers have had bunks.
Some also had a keel roller or two. Lately I have added pvc guide posts located in the aft 1/3 of the trailer. They help a lot. The other thing I do is back the trailer in far enough to wet the entire length of the bunks and then pull forward to expose 1/3. Wet bunks help with winching. |
#17 |
Damage wise it could, depending on the boat. Whalers for ex., should have bunks because the rollers can form indentations in the hull over time. Of course I’ve heard people may they’ve never had a problem.
I just replaced my little whaler trailer and got the guides too. A little overkill for a 13 but they do make it so much easier with wind and current. All I have to do is catch the bow on one post and I’m in. I also want my boys to start learning how to run and load the boat. They’re also really helpful for backing up. I’ve been having people drive that aren’t used to trailering so the posts help them know where the trailer is. I did have side bunk guides in my 20’ but find they could be hard to see as they were often submerged. I’ve never had a roller trailer so don’t know which is better. I will say few weeks ago in the cape At one ramp I couldn’t get my bunks wet. That was a little challenge lol. But we managed to get it off the trailer. Granted the boat doesn’t weigh much. Sent from my iPhone using Tapatalk |
I’ve also seen some suggestions to “soap” the bunks so they don’t stick when the boat is layed up for lengthy periods. This also helps with winching the boat the final few inches if required.
#19 |
Rollers work both ways...
Is it "Common Sense" isn't.
#20 |
I did forget one thing that is a draw back, with carpeted bunks, but can be ignored if you don't use your boat in the really cold weather.
When its really cold in the 20's boats won't slide off of the bunks. Have had it happen a few times when launching. Surprised me, frozen right to the trailer until the lake water melted it. Just like it was supper glued on. |
#21 | |
