So I am looking at a building lot that has a stream running right through the middle of it.
Does someone know if I can legally keep the stream, but move it 70 feet away to a nearby perimeter lot line? Obviously moving it will allow me a larger building envelope footprint. I know wetlands can be moved if they can be replicated elsewhere on a property, but I was unsure about a seasonal stream. Anyone out there in Forum land have any knowledge about this type of situation? |
Usually developers doing a subdivision try to put lot lines close to brooks, instead of in the middle of the lot. There may be drainage issues that drove the surveyor to do the layout in a particular way. Is there a drainage easement? How is it described in the deed?
You might find someone from the NH Association of Natural Resource Scientists who can help you. Members are listed on their website http://nhanrs.org |
#3 | |
Shore things, can you divert, dam or otherwise tamper with a stream that is only a runoff/drainage stream? This is not near a lake but the drainage eventually empties into a beaver pond.
Why divert it? Build over it with a lexan floor over the stream. It’s been done!
Sent from my iPad using Winnipesaukee Forum mobile app |
| The Following User Says Thank You to Pineedles For This Useful Post: | ||
Hillcountry (08-16-2019) | ||
#6 | |
Why don't you jump ahead 10 years into the future and see how it went?
[insert witty phrase here] |
Frank Lloyd Wright built his famous "Falling Waters" over a stream. In the 19th century mills, etc were built on the side of a river. Now DES knows better and you can't build next to moving water. In Florida, you can dredge almost anyplace, throw the spoil onto the shore to make building lots, add concrete sea walls and you've got "new" land.
This whole thing is crazy. "You can't build that anymore", but the placers built 100 years ago used 300 feet of frontage where new regulations forced building to 100' of frontage and more intense use. Yes, you don't have to be (as) rich, but the intensity of shorefront development is a lot different. Rich, (big shorefront) vs, only a little less rich, and have smaller frontage, with more intense development. Hmmm. |
You CAN do it if DES will approve it. Your reasoning for moving a wetland of any kind is typically the main consideration. In this case if the reason is simply for inconvenience of building, they will not let you move it. Even if they did let you move it, it is prohibitively expensive. It is typically $1 million per acre to move wetlands (or ~$23 a square foot). Again assuming they’ll even approve it.
Surface run-off is generally not considered to be within Wetlands jurisdiction. Once there is enough natural concentrated flow to incise a channel then it begins to become a watercourse that would be considered jurisdictional, whether there is water visible in the channel year round or not. Roadside and other manmade conveyance structures are not considered jurisdictional unless they were dug into a jurisdictional wetland or they intercept a natural stream at that point they do become part of wetlands jurisdiction.
| The Following User Says Thank You to Onshore For This Useful Post: | ||
Hillcountry (08-15-2019) | ||
#10 | |
Take a look uphill: If there are spans of irrigated green lawn, chances are very good that you'll have the same (or worse) runoff experience. Next door, my neighbor had a concern whether their abutting lot could be sold as a building lot. Their new survey showed a very wet lot, and the surveyor had written a note on it, recommending against building on it. That neighbor provided a copy of the survey to me—which I still have—before the lot was sold. As it turned out, a builder came in, dumped tons of fill, and diverted the existing "babbling brook" to our side of their lot. Where we once had no view of our neighbors, the new owners built to the maximum height, so there's three stories of night-time lighting. The other side of their lot has a shared driveway that washes out every summer. Some of the hill's moisture oozes under the house, and pools-up in the yard facing the lake. Why it produces a red stain, I don't know. There was a buried commercial aviation gasoline tank uphill (serving the airport) at one time. The pre-existing septic system and leach field was filled in and a new system, shared with the neighbor, was installed. Aside from the negatives of putting the porch facing our porch—renting-out all summer—the babbling brook turns to mud in summer and has doubled in size. The brook, which is still mostly seasonal, soaked the boundary line to the point that at least eight mature trees have been blown over (to angles of ~45°). The trees that survived have struggled to send up new foliage: Although the greenery is welcome, those trees are making the strangest of privacy fences. . |
#11 | |
My well water in Hooksett has very high iron content and stains everything if used untreated. My sediment filter which is the first in line from my well pump output into the house turns red and catches a rusty colored sediment similar to mud. Kinda gross but hey it's what comes out of the ground! |
#12 | |
Trying to move a stream legally is like finding an old Indian arrow head and reporting to the news media. |
#13 | |
A wise person, maybe Yogi Berra, maybe Confucius, maybe Father Time, once said, "It is not nice to fool Mother Nature", and I think this applies in this case (it will come back to bite you).
#16 | |
https://www.youtube.com/watch?v=ijVijP-CDVI |
| The Following User Says Thank You to FlyingScot For This Useful Post: | ||
camp guy (08-17-2019) | ||
#17 | |
Is it really a "seasonal stream" - what it actually is by the states definition will lead you to the answer. Seasonal run-off is not a "stream". Does the stream have a name?
After answering the questions truthfully - yes wetlands can be managed but you are not going to be allowed to change the exit point of a water flow or stop the water flow. Not to be confused with storm water retention ponds. :-) Quote:
#18 | |
Something I forgot to ask:
Is the lot shorefront--to a lake? Quote:
#19 | |
If the river makes the lot unbuildable - then time to find another lot. |
