Old 04-23-2019, 08:29 PM   #1
jam1083
Default Portable Potty pumping
New boat owner. Bought a tri-toon wondering if I put a portable potty on it are there places that can pump out portable potties?
jam1083 is offline   Reply With Quote
Old 04-23-2019, 08:48 PM   #2
Install one with a pump out and it will be very easy. Without the pump out option I think it will be tougher. Look for Thetford MSDs.
Meredith has two free DIY pumps.
If you want privacy on the MSD, a real poncho (not a Sears poncho) would be the minimum requirement.
jam1083 (09-04-2019)
Old 04-23-2019, 09:22 PM   #3
I had those on boats for years.
A lot of times with the two part portable potties the bottom tank has a handle and you can just take it out dump it into any toilet.
Just keep disposable rubber gloves on the boat.
upthesaukee (04-23-2019)
Old 04-24-2019, 09:06 AM   #4
dt5150
i have one on my boat and it never gets used. a 5 gallon bucket and a plastic bag is much easier to deal with.
The Following User Says Thank You to dt5150 For This Useful Post:
Cal Coon (09-05-2019)
Old 04-24-2019, 11:45 AM   #5
Default ... a $17 luggable loo that works, more for less
Over in the camping section at Walmart, they have a $12 plastic toilet seat and lid that fits onto the top of a 5-gal plastic bucket. And, there's two different lids that snap on tightly to the same 5-gal bucket, so it can be sealed up and removed for dumping and cleaning into the toilet, back home. All three items run about $17.
Combine this with the Consolidated Communications wifi internet service, and you are good to go .... with no working water and no heat .... even in January .... when your ancient septic system has done froze up ... or something!
Guaranteed to increase your appreciation for indoor plumbing that works.
Old 04-24-2019, 11:58 AM   #6
Question
Just curious FLL, do you go to Walmart to take a dump so as not to put a strain on your septic system and reduce pump out costs?
Old 04-24-2019, 12:29 PM   #7
True Walmart story; no, but last time I used that Plymouth Walmart rest room, there was absolutely no toilet paper, and some hyper guy in the next stall asking if I had any toilet paper ..... exit .... outta there, fast!
Old 04-24-2019, 01:09 PM   #8
TheRoBoat
Default Made it through a summer on the island....
.....with these
https://tinyurl.com/y56w2yy2
TheRoBoat is offline   Reply With Quote
Old 04-24-2019, 03:52 PM   #9
salty dog
salty dog's Avatar
Default Good in a pinch
I use the "Luggable Loo" also. Even though you let people know to "go" before
you leave the dock, 3 or more hours out and with water to hydrate, it can sometimes be difficult to hold out that long. No privacy with our 21' bowrider either, so I got one of these privacy shelters that does the job just fine; also good for changing in or out of swim trunks or suit.
https://www.amazon.com/dp/B00MDV13YQ...E6XVO9W87&th=1
The Following User Says Thank You to salty dog For This Useful Post:
Old 09-04-2019, 11:49 PM   #10
jam1083
Thanks for your input. Have a privacy area on the pontoon. Used the potty a couple times. Kind of disgusting but necessary at times especially now that it’s getting colder. Next boat needs a head 😆.
Old 09-09-2019, 11:02 AM   #11
Patofnaud
"Over in the camping section at Walmart, they have a $12 plastic toilet seat and lid that fits onto the top of a 5-gal plastic bucket. And, there's two different lids that snap on tightly to the same 5-gal bucket, so it can be sealed up and removed for dumping and cleaning into the toilet, back home. All three items run about $17."
Can't say I always agree with FLL, but this time, he is spot on.
5 gal bucket, lined with small kitchen trash liners x2, some kitty litter, and a snap-on toilet seat is MUCH nice than dealing with blue water, rubber gloves, flushing out, pumping out. And, it sits higher than one of the suitcase-style so you are not kissing your knees.. Keep a small plastic container of kitty litter nearby to cover. and to lay a base down It actually does not smell bad either.
Old 09-10-2019, 07:30 PM   #12
Hillcountry
Hillcountry's Avatar
Luggable loo here as well. Thanks for the kitty litter tip.
After a few “relief sessions” the bucket starts to be quite odorous!
Old 09-10-2019, 07:41 PM   #13
Hill,
Try these they work great! I use them for ice fishing. Fits inside the “Luggable Loo” bucket perfectly!
https://smile.amazon.com/Reliance-Do...s%2C338&sr=8-1
Hillcountry (09-11-2019)
Old 09-11-2019, 01:25 PM   #14
Hill,
I couldn't resist. Do they catch a lot of fish?
Old 09-11-2019, 02:17 PM   #15
Now that's funny right there!!
In all seriousness, just brown trout...
Hillcountry (09-11-2019), rander7823 (09-17-2019)
Old 09-11-2019, 06:08 PM   #16
Hillcountry
LMAO! Just don’t release them Dan!
Old 09-14-2019, 10:15 AM   #17
kauriel
We had pump out installed last year so we can get pumped out at gas dock. It was well worth the expense and the extra tip when we get gas!
kauriel is offline   Reply With Quote
Old 09-15-2019, 01:52 PM   #18
Default No kitty litter
Whether Septic or sewer, that's not the place to be dumping kitty litter. Same with "flushable" wipes. Regardless of the label, they don't break down and cause significant additional treatment/expense at the wastewater treatment plant. They'll also clog up your home septic system.
ApS (09-15-2019)
This page was generated in 0.10112 seconds
