Old 01-16-2019, 03:26 PM   #1
bclaker
Default iPad e-mail
Does anyone know how to delete all e-mails on iPad with a single set of strokes. I used to be able to do it using the MOVE button, but that doesn’t work any more. I have about 50,000 e-mails that need to be deleted. I posted the question on Facebook but got no answers. I also tried Googling it and several said the way I used to do it, but one said with one of the OS updates, it was deleted and they have to be deleted one at a time.
bclaker is offline   Reply With Quote
Old 01-16-2019, 03:35 PM   #2
You have to read them all first.
Old 01-16-2019, 05:22 PM   #3
joey2665
joey2665's Avatar
Go into the email folder hit EDIT, select the emails to delete, then hit trash at the bottom
Old 01-16-2019, 06:57 PM   #4
Woodguy53
Default IPad email
Likely it’s the way your email service is set up. Pre-iPad you likely used a PC or Mac that was connected to your isp. When you deleted email it deleted from your isp servers. Once you go to multiple access points - ie iPhone,iPad and PC the email on your mobile devices will not delete off the server unless set up to do that. If you only have an iPad and don’t access email from other devices it can be set up to delete when downloaded
If you have multiple devices either your ISP supplier or Apple support can help you with the best way to handle it
Woodguy53 is offline   Reply With Quote
Old 01-16-2019, 08:54 PM   #5
Downeast
Default mass emails flocking to the trash can..
i believe you :
1- hit edit (circles appear)
2- check just one email in your box
3- hold finger on "move" (located at the bottom of screen)
4- while holding finger on "move", un-check that one email.
a folder should then display
5- click trashcan
and all emails should migrate to the trash folder at one time.
again, not confident 100% this is applicable to every IOS version.
The Following 2 Users Say Thank You to Downeast For This Useful Post:
bclaker (01-17-2019), Slickcraft (01-17-2019)
Old 01-17-2019, 10:19 AM   #6
bclaker
Default Deleting all e-mail messages with one click
That is exactly the way I used to do it, but it doesn’t work now.
Old 01-17-2019, 10:23 AM   #7
joey2665
joey2665's Avatar
You may need to go into the email setting and turn off the option to "archive" emails
This page was generated in 0.09120 seconds
