Old 11-17-2018, 11:08 AM   #1
whkhawks
Default kohler generator service
Hi
I am looking for a local generator company to start up and service a new 7 K Kohler generator that I had installed. We are located in Alton Bay. Thanks for your help.
whkhawks is offline   Reply With Quote
Old 11-17-2018, 04:00 PM   #2
Not to Worry
Default I use this place
https://yestramskielectricalservice....atordealer.com
They are not local BUT the offer 24/7 emergency service and they tune up my Kohler 1x per year.
The Following User Says Thank You to Not to Worry For This Useful Post:
whkhawks (11-17-2018)
Old 11-17-2018, 04:03 PM   #3
We bought our 7K Kohler from New Wave Electric in Laconia.
http://nuwaveelectric.com/
I have not needed service so I don't know how they rate on that. They were good to work with on the original purchase.
Old 11-17-2018, 04:35 PM   #4
Charlie T
Originally Posted by whkhawks View Post
Hi
Why wouldn't you use the company that installed it? Was there a problem?
The Following User Says Thank You to Charlie T For This Useful Post:
Old 11-17-2018, 04:55 PM   #5
whkhawks
No we had no problem at all. I would just like to hire a local company to do the yearly service on it. Thanks
Old 11-17-2018, 04:57 PM   #6
winni83
Ditto on Yestramski. Our electrician installed our 14 K Kohler but Yestramki did the set up and test and has serviced it yearly with no issues.
The Following User Says Thank You to winni83 For This Useful Post:
whkhawks (11-18-2018)
Old 11-17-2018, 11:26 PM   #7
Loub52
Loub52's Avatar
Hi
You might also consider http://generatorconnection.com out of Barrington, NH
I had a 20KW whole house Kohler installed by them in Meredith. They offer an annual service plan that includes 24x7 service in case of an issue with your generators function during a power outage, though I'm unsure if they would consider covering other vendors installs. Worth a call either way.
Thanks,
Loub52
The Following User Says Thank You to Loub52 For This Useful Post:
Old 11-18-2018, 05:24 PM   #8
Same as above. Have had good luck with generator connection.
whkhawks (11-20-2018)
Old 11-19-2018, 10:45 PM   #9
GregW11
I had a whole-house Kohler generator installed in the Meredith area by New Hampshire Generator Installers http://www.nhgeneratorinstallers.com/. They also do my annual service as well as respond to service requests. They have been outstanding and I highly recommend them.
GregW11 is offline   Reply With Quote
The Following User Says Thank You to GregW11 For This Useful Post:
This page was generated in 0.09116 seconds
