09-21-2018, 10:31 AM | #1 |
Flying squirrel invasion
Now that we have gotten rid of the mice we now have flying squirrels in the attic. Tried using Have a heart cage and Ultrasonic pest defenders. Haven't work so far. Concerned that there is a nest with babies being born. What else should we try? We think that they are coming in down the chimney flue. Need to get rid of them before we close up in about 3 weeks.
09-21-2018, 10:37 AM | #2 | |
Sent from my VS988 using Tapatalk
Youtube channel: https://www.youtube.com/user/radiocontester |
The Following User Says Thank You to radiocontester For This Useful Post: | ||
chasedawg (09-21-2018) |
09-21-2018, 10:50 AM | #3 |
A cat would work.
basking in the benign indifference of the universe |
09-21-2018, 10:56 AM | #4 | |
HellRaZoR004 (09-21-2018) |
09-21-2018, 11:16 AM | #5 |
09-21-2018, 11:57 AM | #6 |
Just had the same problem...
They're nocturnal. I had 8 of them. They live in colonies. I stood out in the rain and mosquitos at 3:00 am for a couple of weeks and shot 4 of them with .22 bird-shot.
I gave up on the remaining and had to hire an animal control co. Cost $2,000 for them to seal every single small and large opening (took several hours). Then they installed a "one-way trap door" and the remaining exited. For the next week I heard them scampering all over the house, at night, trying to find a new way in. Forget the traps, poisons, etc. Bottom line? By my own experience, you have a very nasty problem. It took me over 2 1/2 months to get rid of them...And by the way...The animal control companies I spoke to were very backed up and I was told by several that they couldn't even take a look at the situation for more than 2 months.
Gary ~~~~_/) ~~~ ~~~~~~~~ |
The Following User Says Thank You to garysanfran For This Useful Post: | ||
Top-Water (09-21-2018) |
09-21-2018, 12:07 PM | #7 | |
information. They are really difficult to get rid off. |
09-21-2018, 01:07 PM | #8 |
Infrared game cam...
I bought a motion detected game cam and set it up where I thought the entrance was. It accomplished two things...
1. It showed photos that confirmed their entry point 2. It established a pretty reliable pattern of the hours they used their "door". Around 10pm, 1am and 3am. They also establish a latrine for the entire colony to use. Look for brown streaks on your walls or ceilings. Their nest will be near there. .22 bird shot should not hurt your siding. Try a test somewhere.
09-21-2018, 05:31 PM | #9 |
Small holes
FS come in through similar size holes as do mice. The ONLY way to get rid of them is hire a pro who will find the voids and block them for entering BUT first they have to install a trap that lets them out but not in...otherwise!!!
09-21-2018, 09:22 PM | #10 |
09-21-2018, 09:24 PM | #11 |
09-21-2018, 09:26 PM | #12 |
flying squirrels
09-22-2018, 06:47 AM | #13 | |
09-22-2018, 07:33 AM | #14 | |
I believe we had one that broke in through a screened louvre on one of our two rooftop dormers but they could only get into the dormer wall because we have cathedral ceilings. We’d hear them scratching around in the dormer wall and I would take my walking stick and reach up and whack the wall. The noises disappeared eventually. |
The Following User Says Thank You to Hillcountry For This Useful Post: | ||
chasedawg (09-22-2018) |
09-22-2018, 07:50 AM | #15 | |
Something to consider...
It seems you have access to them indoors. That's a good START. I didn't have access to them except when they exited or entered. If you seal them in, they'll gnaw through anything to try and get out. Some people worry about the odors of them rotting. But a bigger concern...If you are successful in removing them all, you MUST take care of any place their distant relatives can get in (they've probably already shared their location on the FS Forum) ...And they can squeeze through extremely small holes. Seal up everything...EVERYTHING! Please keep us posted...
09-22-2018, 08:03 AM | #16 |
Sealing holes...
Don't just caulk or use some sort of filler to seal spaces. What made my treatment so expensive was that they used metal wire mesh, same color as my siding, then they went over the mesh with caulk of the same color. The rodents can't gnaw through metal. I was amazed at how they could fit this mesh into the smallest holes. I was told that, what they did, also increased the insulation value of the house greatly.
09-23-2018, 01:31 PM | #17 |
Repellent Spray
I live on a dead end dirt road in Vt. And my prooerty is loaded with oaks. It’s a squirrels paradise. They got into my pole barn and chewed through one of the hydraulic lines on my tractor. The tech had to remove the fuel tank and ROPS to get to it. Cost me over $1000 to fix. I bought a deterrent spray from Home Depot which contains garlic,black pepper, peppermint and others things that wildlife do not like to smell. I spray this around my tractor and ATVs about every 30 days and haven’t had a problem in 3 years.
Won’t be a permanent fix for you but maybe you can spray to move them along until you can figure out a permanent solution. They sell a few different brands, powder and liquid. The one I have been using for the last year is a spray that is sold as a TomCat brand. We rent a summer place in Gilford and the flying squirrels were taking over the outside patio. They were actually getting into the gas grill. I brought up the jug of repellent spray. Sprayed the inside and outside perimeter of the privacy wall and no more issues the rest of the summer. Just reapplied every 3 or 4 weeks. Good Luck |
09-23-2018, 03:04 PM | #18 |
Gary's advice/situation was similar to mine and I had to use an animal control service as well. They got in through the attic and made there way down to my basement through the walls. As stated they need very minimal amounts of space to get in. My guy sealed everything up with a wired mesh product and I have been good ever since.
09-25-2018, 12:19 PM | #19 |
Flying Squirrels in the attic
Approximately a month ago we heard critters in the attic. They were noisy from about 2 to 4 am. Contacted several pest control companies but only heard from J P Pests. They sent out a wildlife expert for free who suggested we had flying squirrels. Suggested we screen in our gable vents among a few other items. Followed his suggestions and we have had a quiet nights sleep ever since.
The cottage is over a 100 years old and very porus. We have always had mice in the dirt basement, but never anything in the attic. Hopefully have solved the problem. Hope this helps, Bill |
09-25-2018, 01:56 PM | #20 |
Off topic, but I had to say that every time I see the topic of this thread, I think a new cover band is coming to Flying Monkey.
Flying Squirrel Invasion, kind of like the British Invasion meets the Flying Squirrels. https://www.youtube.com/watch?v=TVC0PG6WBQs |
The Following User Says Thank You to Patofnaud For This Useful Post: | ||
beantownbaby (09-26-2018) |
09-26-2018, 11:32 AM | #21 |
Get rid of flying squirrels
Thought I posted this - but I don't see it! Anyway, we had this problem several years ago. Our cats alerted us to the noises they were hearing from the attic by racing up the stairs and standing still to listen. We hired Alpha Omega Pest Control in Meredith to eliminate them. I found one dead in the basement that must have come down the trace - but Alpha came and set up an "exit only" type of "door" in the roof... they can get out but not back in. He sealed up every hole he could find. We haven't had a problem since with the squirrels- but the mice and voles are driving me nutso!
