Old 08-14-2005, 11:00 PM   #1
dmjr
dmjr's Avatar
Default Repairing of Dock Cribbing
Hello,
I was wondering if you need a permit to repair the cribbing on a wooden dock?
Thank You
Old 08-15-2005, 08:12 AM   #2
Onshore
Default Yes...
You will need a permit to repair anything below the water.
Old 03-31-2006, 12:25 PM   #3
lakeboy142
Post Permit for Cribbing
Originally Posted by dmjr
Hello,
Thank You
Yes, about five years ago I replaced/installed posts around my dock and I had to go through the permit process. If you start early, keep notes and copies of everything you do things will work out. If you get a company to come in and replace the cribbing the company may do the permit process
for you. They know all the ins and outs in the permit process too.
Lakeboy142
lakeboy142 is offline   Reply With Quote
Old 03-31-2006, 12:34 PM   #4
RLW
RLW's Avatar
Question Repairing of docks
I was told that I needed a permit for construction, replacement and/or repair of anything above and/or below water as long as it is on water or attached to land and above or below water.
Old 03-31-2006, 03:40 PM   #5
jimbob1603
Default Permits for Everyone!
Welcome to the People's Republic of New Hampshire!
Might as well call it Lake Massachusetts!
Permits are absolutely required to construct, repair, or demolish a pier, dock, or float. After submitting your permit application to the local Conservation Commission, they forward it to the State environmental folks with their recommendation. If approved by the state, you then apply for a local building permit. If approved by the local building inspector, you are issued a permit.
Or, you can do what many waterfront folks do (provided you are on good terms with your neighbors): just discreetly do the work ..... be quick, clean, considerate, and quiet about it. But, don't expect this method to work for something obvious; like re-roofing your boat-house.
jimbob1603 is offline   Reply With Quote
Old 03-31-2006, 04:02 PM   #6
Steveo
I did my dock several years ago. I did not have to get a permit if I was simple replacing/repairing the decking or substructure not touching the water. The work had to cost under the minmum cost for any permit. At the time you didn't need a permit for work costing less than $1000. That was in Alton but several years ago.
Old 04-10-2006, 03:32 PM   #7
Province Girl
Default Dock Repair
You do not need a permit from the Wetlands Bureau for the work conducted above the water as long as there is no change in the dimensions. You might need a building permit from your town though.
Province Girl is offline   Reply With Quote
This page was generated in 0.10252 seconds
