Old 12-11-2017, 08:14 AM   #1
Default Firewood - not split
Is there anyone locally who sells firewood not split and if so what's the cost of getting it this way?
Old 12-11-2017, 09:23 AM   #2
dpg, are you asking about so called "grapple loads", that being logs that are approximately 8' long for the customer to cut and split, or are you looking for wood cut to a specific length (say 16") but not split.
The problem with the latter is that many firewood providers utilize firewood processors that take a log, cut a specific length and then that length is dropped down where a hydraulic ram pushes it through a splitting wedge. This is what my wood guy has for his firewood business.
Good luck in your search.
Sent from my SM-T580 using Winnipesaukee Forum mobile app
Old 12-11-2017, 10:29 AM   #3
Hillcountry
Hillcountry's Avatar
Not to disqualify what you said but every grapple load I have seen or bought has been tree trunks of 18-20 feet long. Lots of work to cut, split, move, stack etc.
That’s why firewood warms you up at least four or five times!
Old 12-11-2017, 10:43 AM   #4
I agree, lengths can vary. My neighbor gets a couple of loads each year, about 8' or 10' long, probably because of the space to drop the wood and the size of three truck that delivers it.
I thought about doing it a year or two ago, but decided I didn't need to create that much heat, jyst the heat to stack the splits and then burn the wood. 😉
Old 12-11-2017, 11:01 AM   #5
jbolty
we used to always get full tree lengths but you need to get it cut and stacked minimum a year out. We would cut to 4' then stack and cut to stove length and split it a year later. Lot of work.
Old 12-11-2017, 12:37 PM   #6
ok thanks all but does anyone know of a person who delivers like this? Lengths or cut to size ready to split doesn't matter either works. What's the approximate cost 10% cheaper than split, 25% 50% ?? I'm aware of the work involved.
Old 12-11-2017, 02:47 PM   #7
Try these. Got the link via a search for logging near laconia.
https://www.yellowpages.com/laconia-...ging-companies
Old 12-11-2017, 03:59 PM   #8
Hillcountry
Generally a lot cheaper to buy by the grapple load...I would hazard a guess of 50% cheaper. A grapple load could yield multiple cords depending on how it’s cut and split.
Old 12-11-2017, 05:11 PM   #9
Doobs41378
Accurate tree service says it charges 1450 for a grapple load in NH which is about 12 cords it says.
Old 12-11-2017, 09:35 PM   #10
Hillcountry
That’s more Than 50% right there and I see seasoned wood going for $300 and up per cord!
Old 12-12-2017, 03:17 PM   #11
MBNeckguy
Try James Armstrong (603) 662-2791. He has very reasonable prices and still does all of his cutting and splitting by hand. Unsplit should not be an issue.
Sent from my SM-N920R4 using Winnipesaukee Forum mobile app
MBNeckguy is offline   Reply With Quote
Old 12-12-2017, 04:34 PM   #12
JEEPONLY
Default dpg- wood
I have three oak trees I would offer to have taken down for the wood (clean-up included).
Old 12-12-2017, 04:42 PM   #13
Doobs41378
By another member here? That’s a huge liability risk if so.
Old 12-12-2017, 05:40 PM   #14
The name fits his occupation. That kind of work will make you arm strong. Ha,Ha.
Old 12-13-2017, 01:00 PM   #15
Thank's for the responses...
JEEPONLY - No thanks not my cup of tea...
This page was generated in 0.09645 seconds
