Old 01-18-2016, 10:13 PM   #1
modrama
Default Water supply pipe
Wondering if anyone has any tips on locating our water supply pipe at the bottom of the lake? Bought a lake house last year (small lake in Maine, not Winni) and tried all summer to find our waterline. Thinking it is buried and pops up away from the shore but unable to locate it. Lots of dirt on our filter after the pump. Any tips?
Thanks in advance for the advice.
modrama is offline   Reply With Quote
Old 01-18-2016, 10:56 PM   #2
Charlie T
Default Easy
Make up a fitting at the pump inlet and put some compressed air back thru the water inlet. The bubbles will lead you right to the waterline.
Old 01-18-2016, 11:19 PM   #3
Lakeboater
Default Foot valve
Will you get the bubbles if you have a foot valve? Or is one not necessary if the pipe is in the lake
Old 01-19-2016, 04:13 AM   #4
wifi
wifi's Avatar
No, that is the purpose of a FV, to prevent back flow.
Old 01-19-2016, 01:01 PM   #5
Maybe put on a diving mask and some flippers, and go diving round in a likely spot in maybe six feet of water.
Old 01-19-2016, 01:44 PM   #6
Maybe you could push a wire down the line from the house, then use it to locate the path of the line from house to shore, much as is done when a gas line with tracer wire above it is located. If you know the point on the shore where the line goes to, that ought to narrow down the part of the lake to search for the inlet.
This page was generated in 0.11315 seconds
