Old 06-02-2005, 04:55 PM   #1
searay220
Exclamation WARNING-For Boaters
Last weekend while on the lake I could not believe the amount of stuff / junk in the water.Anything from shoes to branches to parts of docks.And of course I had the found a large 2x8 by about 6 feet long board the hard way.It was just below the surface of the water and could not turn fast enough before hitting it.So anyway just a warning before you go out this weekend becareful and enjoy.
searay220 is offline   Reply With Quote
Old 06-02-2005, 05:00 PM   #2
camp guy
camp guy's Avatar
Default Warning for boaters
While boating today along the Broads side of Wolfeboro Neck, traveling north, about even with the Walgreen triple bay boathouse, I noticed a red and white marker bouy I had never seen before at that location. Possibly this is to keep people off shore from the boathouse area, but there are certainly no rocks in that area. Just curious. If you normally boat close to the shore in that area...look out... the red top with get you ! Enjoy your boating.
Old 06-02-2005, 05:55 PM   #3
Mee-n-Mac
Mee-n-Mac's Avatar
Default Blame the rain and high winds
Like searay said there's just a lot of everything out there. I pulled some 2x8 and large branches out (the easy way) last Sat. Coming back from Meredith on Sun afternoon you'd have thought several houses had sunk at various points along the way. There would be clumps of debris to manuver around every mile or so (or so it seemed). Most of it was branches which I assume were blown in courtesy of the last storm but there was other dock / raft stuff as well. I pulled in what I could but it's like boating in the 2 weeks after ice out right now. Keep a good lookout
Mee'n'Mac
Old 06-06-2005, 02:42 PM   #4
kchace
Default I found one of those 'clumps'
I found one of those clumps of debris on my way out of Meredith bay late on the day last Sunday. Took the tip of one propeller blade off. I had even been warned and was watching out for it, but I saw the stuff too late.
Ken
Old 06-12-2005, 07:17 PM   #5
itchin for fishin
Default Junk just keeps on going
Finally got an opportunity to get out on the water today and geez I couldn't belive the amount of junk still floating around. When I started out, the pollen flows were amazing (as my eyes have been trying to tell me this past week). While cruising around Rattlesnake, all of a sudden a piece of 2x6, just the kind left from bob houses. Clocked it dead on even temporarily the speedo hole in the out drive ($^@#! Further cruising found plenty of branches and even some small campfire logs. This is the latest in the season I have ever seen so much debris and I can't understand why.
One thing the pollen flows did achieve was helping you find debris. Where you found tons a floating pollen, you typically found debris. Is this the State using a cheap marker system? And yes we fished.
itchin for fishin is offline   Reply With Quote
Old 06-12-2005, 08:34 PM   #6
Aquadeziac
Aquadeziac's Avatar
Angry
We-e-ellll.....People, if you get your ski-tow rope extricated from your prop after you back over it, please take it back to shore with you. You think you had a hard time taking it out of your prop, think of it getting sucked up into a PWC jet-pump!
Aquadeziac is offline   Reply With Quote
Old 06-13-2005, 09:47 AM   #7
Bummer Aqua,I've been there before with a dock line spun around my impeller.The worst part is I didn't know it was there and when trying to start it,blew a starter relay which ended my weekend of boating before it begain.I was on the lake this weekend and also found an incredible amount of debris floating everywhere,along with huge pine pollen flows.Most of the debris that I saw were branches with the occasional coke bottle but much more than I have seen in the past.Be carefull out there!! SS
Old 06-13-2005, 03:40 PM   #8
Wolfeboro Matt
Wolfeboro Matt's Avatar
Default Big Log
I saw a great big log on Friday - it must've meen 2 feet in diameter and 3 feet long. Floated with only about 1/2 -1 inch out of the water. I never would've seen it had I not been going at headway speed. Bummer was the thing was so heavy and slippery I couldn't even manage to get it out of the water...
Wolfeboro Matt is offline   Reply With Quote
Old 06-13-2005, 11:33 PM   #9
sum-r breeze
Default Chamois cloth
My wife and her friend were out on a brand new sea doo and almost sucked up a CHAMOIS cloth. That would have been an expensive repair bill!
sum-r breeze is offline   Reply With Quote
Old 06-15-2005, 07:30 PM   #10
According to Bizer, there is a rock there. It's on my paper chart and my C-Map chart but the marker is on neither. I must've just missed that rock countless times. Glad to see a marker if Bizer is right and I bet they are...
Old 06-18-2005, 12:08 PM   #11
Exclamation BOTH are there!
There is both a rock ledge and new marker there, which I mentioned in May.
As camp guy has implied, the marker kind of "sticks out into" the normal traffic pattern there, so it will likely become a headache for the people who do Winnipesaukee's marker maintenance.
(The marker does not appear on Bizer's, BTW).
Wolfeboro Matt: I found two smaller "logs" similar to what you are describing. If yours was cut off by chainsaw -- and has no bark -- it may have been one of those dock piling remnants (especially if it was slippery, suggesting no bark).
I think it's the construction-barge people cutting off the tops* and sharpening the tips** of dock pilings.
*...after driving them in, to "level" a new dock piling
**...the bottoms of pilings to a point -- to drive them in faster.
Somebody needs a talking-to about where to discard "the excess".
Is it
"Common Sense" isn't.
Old 07-18-2005, 08:45 AM   #12
MJM
I was very happy to see this marker had finally been installed at Umbrella Point. We DESTROYED a prop there once, not knowing about the huge piece of ledge....
MJM is offline   Reply With Quote
Old 07-18-2005, 08:58 AM   #13
Default Marker?
This one, off Walgreen's?
Is it
This page was generated in 0.13431 seconds
