Old 07-30-2015, 03:47 PM   #1
Default Boat Trailer maintenance
I have a boat trailer with rollers.
How should I lubricate these rollers ?
Grease, Oil, Silicon spray?
Thanks,
Bigdog
Old 07-30-2015, 04:23 PM   #2
trfour's Avatar
Post bigdog...
I always used vegetable oil in a squirt can. It won't eat the rubber rollers, or put toxins/carcinogens in the Lake!
Hope this helps...
Terry
_______________________
Old 07-30-2015, 06:24 PM   #3
Thanks,
Bigdog
I would use Fluid Film on any rollers that get dunked. If you already have corrosion, you may want to swap the bolts for stainless and the rollers for urethane. My trailer has two rollers that never go under water and I use Mercury 101 on them.
bigdog (07-31-2015)
Old 08-05-2015, 03:02 AM   #4
CooperS7777
I've had great luck with Dupont Multi-Use Teflon spray. You can generally pick it up at the local hardware store. It forms a dry, waxy coating, protects for a good length of time, and wont wash off when you splash your boat! It also works great for lubricating chains on equipment, motorcycles or bikes.
This page was generated in 0.07143 seconds
