Old 07-09-2015, 03:47 PM   #1
Default Fuel shutoff valve?
After having to disassemble, clean, and rebuild my Mercruiser two-barrel carburetor, I wondered about the possibility of installing a shutoff valve in the fuel line, close to where it enters the carburetor. There is one on the line from my snowblower fuel tank, and when I've finished using that each time I close the valve, leaving the engine running at a fast idle until it runs the fuel out of the carburetor. Would that approach work at the end of boating season to help with the problem of the (considerably larger) boat carb fouling as the gas left in the bowl slowly evaporates or fouls due to the ethanol in it, treated or not?
Old 07-09-2015, 11:28 PM   #2
While your plan may be helpful, good results can also be had using StaBil in the tank.
Old 07-10-2015, 05:32 AM   #3
Default Why
I don't know the age of your snowblower but I am wondering why you want to empty the carburetor after each use. The gas keeps rusting away and also keeps gaskets wet. My thought would be to leave the gas in there, and as was said, put Stabil in at the end of the season, still leaving it wet.
I do understand the safety of a shutoff valve but I would use it only to limit the amount of fuel that could spill to just the fuel that was in the carburetor.
wynndog (07-17-2015)
Old 07-10-2015, 10:17 AM   #4
HomeWood
HomeWood's Avatar
Regular use of marine Sta-Bil (blue formula) and you're good to go. I also like to throw in a dose of Sea Foam now and then in my recreational vehicles.
The Following User Says Thank You to HomeWood For This Useful Post:
LIforrelaxin (07-13-2015)
Old 07-10-2015, 03:04 PM   #5
Knomad
On a lot of boats the shut-off valve is located on top of the fuel tank. Commercial boats are required to have a shut-off valve external to the engine compartment in case of a fire. Boats with fuel injection do not need a shut-off valve.
To keep the carburetor clean use marine grade Valtek, Startron, or Stabel every time you fill up and especially when you store the boat.
Old 07-16-2015, 04:25 PM   #6
bt99
If you're comfortable doing low voltage electrical work, how about putting in a switch that kills power to your fuel pump? My Mercruiser engine has an external fuel pump, so the installation was really simple.
bt99 is offline   Reply With Quote
Old 07-18-2015, 08:50 PM   #7
The fuel pump on a carbureted engine is typically mechanical, not electric.
Old 07-19-2015, 10:06 AM   #8
Default Kill two birds...
You could install an outboard type of quick-connect link. This will allow you the option to use a portable tank for a variety of reasons. You can also drain the line to the carb with less spillage. You may want to use a rag or a bowl to catch the drips for safety reasons.
This page was generated in 0.22571 seconds
