Old 05-31-2015, 09:37 AM   #1
Heading4thelake
Default windshield problem
My windshield on my bow-rider has gone out of whack and won't close correctly, can anybody recommend a place to take it, my marina says they don't have the time, it's a walk thru and it doesn't line up.
Heading4thelake is offline   Reply With Quote
Old 05-31-2015, 09:56 AM   #2
I have a Sea Ray bow rider that did the same thing.
On mine there are two rods that hold up the windshield on either side of the walkway.
These rods can be twisted to extend or shorten them.
With the right direction and amount of twisting you can get the windshield back into alignment.
If you feel the need to use a tool other than your hand, I suggest a small set of round jaw Channel Lock type pliers and some padding to protect the finish.
Try not to crush the rods!
Good luck, I hope this helps.
Heading4thelake (05-31-2015)
Old 05-31-2015, 12:55 PM   #3
The hinge may be a bit "sprung" on one end too. You can squeeze it back together using pliers with the windshield closed.
Old 06-01-2015, 07:02 AM   #4
You need to find a new mariner to do business with.
Heading4thelake (06-01-2015)
This page was generated in 0.07397 seconds
