Nautical Terms:
I know some who read this forum are not sailors so I will try and acquaint you with a few nautical terms. If you do understand my ramblings or know some more please leave a comment below:- AHOY The first in a series of four letter words commonly exchanged by skippers as their boats approach one another BAR Long. Low lying navigational hazard, usually awash, found at river mouths and harbor entrances, where it is composed of sand or mud, and ashore, where it is made of mahogany or some other dark wood. Sailors can be found in large numbers around both. BOOM A laterally mounted spar to which a sail is fastened, used during jibing to shift crew members to a fixed, horizontal position. Also the sound a boat makes if the gas bottles are not connected properly. BULKHEAD Discomfort suffered by sailors who drink too much CABIN A cramped, closet like compartment below decks where crew members may be stored – on their sides if large or on end if small – until needed. CALM Sea condition characterized by the simultaneous disappearance of the wind and the last cold beer. CHANNEL Narrow stretch of deep or dredged waterway bordered by buoys or markers that separates two or more grounded boats. CURRENT Tidal flow that carries a boat away from it desired destination or toward a hazard. FITTING OUT Series of maintenance tasks performed on boats ashore during good weather weekends in spring and summer months to make them ready for winter storage. FLIPPER Rubber swimming aid worn on the feet. Usually available in two sizes, 3 and 17 FLOTSAM Anything floating in the water from which there is no response when an offer of a cocktail is made. FLUKE The portion of an anchor that digs securely into the bottom: also, any occasion when this happens on the first try. GALLEY Ancient: Aspect of seafaring associated with slavery. Modern: Aspect of seafaring associated with slavery. GEAR Generic term for any pieces of boating equipment that can be forgotten in the back-seat or boot of a car, left behind on a pontoon, soaked in the bottom of a dinghy or lost over the side of the boat. GIMBALS Movable mountings often found on shipboard lamps, compasses etc which provide dieting passengers an opportunity to observe the true motions of the ship in relation to them, and thus prevent any recently ingested food from remaining in their digestive systems long enough to be converted into unwanted calories. GROUNDING Embarrassing situation in which a sailor returns to shore without leaving his boat. HATCH An opening in a deck leading to the cabin below with a cover designed to let water in while keeping fresh air out. HULL SPEED The maximum theoretical velocity of a given boat through the water, which is 1.5 times the square root of its waterline length in feet, divided by the distance to port in miles, minus the time in hours to sunset cubed. JIBE Course change which causes the boom to sweep rapidly across the cockpit; also, frequent type of comment made by observers of this manoeuvre. LANYARD A light line attached to a small article so that it can be secured somewhere well out of reach. LEEWARD The direction in which objects, liquids and other matter may be thrown without risk of re encountering them in the immediate future. LIFE JACKET Any personal floatation device that will keep an individual who has fallen off a vessel, above water long enough to be run over by it or another rescue craft. MIZZEN The shorter aft mast on a yawl or ketch. Any mast that is no longer there. MOTOR SAILER A hybrid boat that combines the simplicity and reliability of sail power with the calm and serenity of a throbbing engine. OCEAN RACING Demanding form of sailing practiced by sportsman whose idea of a good time is standing under an ice cold shower, fully clothed while re-examining their last meal. PAINTER. A line that is made to come undone when you are not there. PASSAGE Basically a voyage from point A to point B, interrupted by unexpected landfalls or stopovers at point K, point Q, and point Z. PIER Harbor landing place that goes crack, crunch when hit. PILOTAGE The art of getting lost in sight of land, as opposed to the distinct and far more complex science of navigation used to get lost in offshore waters. PORT 1. Left on a boat. 2. A place you wish you never left on a boat. PROPELLER Underwater winch designed to wind up at high speeds any lines left hanging over the stern. RADAR Extremely realistic kind of electronic game often found on larger sailboats. Players try to avoid colliding with “blips” which represent other sailboats, large container ships and oil tankers. REGATTA Organized sailing competition that pits yours against your opponents’ luck. SAILING The find art of getting wet and becoming ill while slowly going nowhere at great expense. SATELLITE NAVIGATION Sophisticated electronic location method that enables sailors to instantly determine the exact latitude and longitude, within just a few feet, anywhere on the surface of the earth, of whatever it was they just ran aground on. SINGLE HANDED SAILING The only situation in which the skipper does not immediately blame the crew for every single thing that goes wrong. SPINNAKER Large beautiful balloon shaped sail used in powerful downwind sailing, collapses at the sides to make control difficult and when lowered stores neatly into the galley and main cabin and heads all at the same time. TIDES The rise and fall of ocean waters. There are two tides of interest to mariners: the ebb tide sailors encounter as they attempt to enter port and the flood tide they experience as they try to leave. FLASHLIGHT Tube in which to store dead batteries. YARDARM Horizontal spar mounted in such a way that when viewed from the cockpit, the sun is always over it. Well now you know the true meaning of as many nautical terms as I do. Can you think of anymore nautical terms or which is your favorite. Please leave a comment below and let us know. A comment makes writing these posts so worthwhile and your thoughts really matter to us. |
| The Following 10 Users Say Thank You to DBreskin For This Useful Post: | ||
brk-lnt (02-09-2015), chasedawg (02-09-2015), CTYankee (02-12-2015), Dad sold the C * C (02-09-2015), Greene's Basin Girl (02-09-2015), Newbiesaukee (02-12-2015), onceMeg (02-10-2015), Phantom (02-10-2015), pjard (02-09-2015), Tallyho (02-12-2015) | ||
OK....now that's funny stuff!
YAWL: A two-masted fore-and-aft-rigged sailboat found mostly in southern waters
| The Following User Says Thank You to Pricestavern For This Useful Post: | ||
DBreskin (02-13-2015) | ||
JETSAM: Anything floating that you pass too fast to offer same cocktail
Wave 'cuz I'll be wavin' back |
What about the BIG one: BOAT - a hole in the water into which you throw money.
BORED - "Nothing better to do than come up with a nautical glossary of terms."
