Old 05-02-2005, 08:51 PM   #1
Iboat2
Default Diesel boats on Lake Winni?
Are there any recreational boats on Lake Winni that run on diesel fuel? If so, where / how do they refuel? Are there any restrictions regarding diesel fueled boats? Thanks.
Iboat2 is offline   Reply With Quote
Old 05-02-2005, 09:53 PM   #2
JPC
Default Deisel Engines
I can't speak about power boaters but most larger sail boats on Winni have diesel engines. You can get diesel fuel at Fays boat yard but you will have to pump it manually into a jerry can. He doesn't sell enough to have a pump at the fuel dock.
Old 05-02-2005, 10:00 PM   #3
Cruiser
There are some larger Sea Rays, that are Diesel as well as the Winni Water Taxi.
Y landing has a diesel pump at lake side
Cruiser is offline   Reply With Quote
Old 05-02-2005, 10:19 PM   #4
Doesn't the Marine Patrol's 42' former Coast Guard (1970's) motor launch, power along on twin 318 V8 Detroit Diesels. Nice boat for just one buck as a surplus gov boat, and how, how, how. JUST HOW big is its' wake? Answer........it is a biggggg wake. (sunglassed yellow face)
Old 05-03-2005, 08:20 AM   #5
PROPELLER
PROPELLER's Avatar
Can you have a home heating oil truck deliver fuel dockside for diesel boats? I was told that was how a Carver at MVYC received its fuel although I never saw that happen & I don't know if its true.
PROPELLER is offline   Reply With Quote
Old 05-03-2005, 11:18 AM   #6
Will
Will's Avatar
Yes, it was a 38' with twin Cummins 375's. I forget the name. There is a boat at Silver Sands, the infamous 53 that everyone knows about which has 450 cummins i believe. I think they use a truck to fuel. I know like mentioned before that a lot of 30' and over sailboats with have a small yanmar.
Will is offline   Reply With Quote
Old 05-03-2005, 01:38 PM   #7
lake4life
Propeller: Yes, I know some folks with a large Carver who have to call a truck to meet them at the docks for a refuel. I mentioned that it sounds like a real pain. They replied that they usually only burn through 2 tanks per season.
lake4life is offline   Reply With Quote
Old 05-03-2005, 01:50 PM   #8
jrc
Default road tax
If you fill your boat with heating oil, don't you avoid the road tax and the hassle of requesting a refund from the state? Maybe a diesel boat is a good idea.
Old 05-03-2005, 02:59 PM   #9
PROPELLER
PROPELLER's Avatar
Will, the Carver I was referring to was called Dunwishn, it was sold last year & is no longer at MVYC
Old 05-04-2005, 11:35 AM   #10
kchace
JRC - yes, you would avoid the road tax if you used heating oil. However, they probably use "off road diesel" which is the same as pump diesel without the road tax. (Its usually dyed red so it would be obvious during a truck stop inspection that you were using incorrect fuel.)
Ken
Old 05-13-2005, 04:25 PM   #11
gtxrider
gtxrider's Avatar
Default Fuel Supply
The Mount runs a diesel, so perhaps at night you could paddle up beside her an siphon off a few gallons.
Be very, very careful.
Anyway I under stand that fuel oil will work but there may be additives in diesel fuel which are not found in heating oil that help clean the injectors. etc...
Old 05-16-2005, 04:41 PM   #12
Will
Will's Avatar
Default Diesel and Home Heating Oil
That is infact correct however, home heating oil will make a mess in injectors. It clogs them like no other. Also home heating oil by nature is a dirty substance. It lacks the necessary biobor that most diesel fuel already has in it. For the extra money its not worth running home heating oil, in the small recreational diesels they just cant handle prolonged use of it. Stick to the regular fuel and save yourself the trouble of 600$ an injector.
Will
This page was generated in 0.25974 seconds
