Old 11-14-2014, 11:52 AM   #1
Greene's Basin Girl
Default Pitch
Does anyone have a good method for removing pitch off a car?
Old 11-14-2014, 11:57 AM   #2
Default Wd-40
Spray a little on the pitch, let it soak for a few minutes and wipe it off!
Unless the pitch have hardened under the direct sun, this is a safe method.
Old 11-14-2014, 11:57 AM   #3
Highlander
Rubbing alcohol on a rag and rub very gently in a rotational direction
Highlander is offline   Reply With Quote
Old 11-14-2014, 12:03 PM   #4
There was a recent thread on the general subject:
http://www.winnipesaukee.com/forums/...hand+sanitizer
I don't know if a car's finish would be different from boat cover, though. Perhaps you first should try whatever you use on a normally hidden part of the paint surface, like inside a door frame.
Old 11-14-2014, 07:09 PM   #5
gtxrider
gtxrider's Avatar
Default Liquid Luster
I use a product called Liquid Luster it removes sap, tar and oil and it leaves a shine and is wax. Other methods remove wax from the surface. It looks like pepto bismol. I first found it at car shows but now I need to order it on line. Works great on the SeaDoo to!
Old 11-14-2014, 08:08 PM   #6
ronc4424
ronc4424's Avatar
I use Goo Gone.....sold every where
How to Remove Tree Sap
REMOVE TREE SAP FROM FIBERGLASS, GLASS, LAMINATE, METAL, PAINTED WOOD, PLASTIC, VARNISHED WOOD, VINYL, WINDOWS, BRICK, CERAMIC, COUNTEROPS, FLOORING, GRANITE, MARBLE, STONE, TILE OR WOOD:
Pretest on an inconspicuous area
Apply Goo Gone
Wait 1-3 minutes
Wipe to remove
Reapply as needed
Wipe off and clean area with soap and water
Use caution not to scratch the surface if a scraping tool is used
Note: Use Goo Gone on non-porous surfaces only. It is safe to use Goo Gone on porous surfaces such as marble, granite, ceramic, concrete and brick only if they are sealed. If a water droplet beads on the surface, that would indicate the surface is sealed and it is safe to use cleaning products like Goo Gone on that surface without it soaking in.
“Better to remain silent and be thought a fool than to speak out and remove all doubt.”
ronc4424 is offline   Reply With Quote
Old 11-14-2014, 09:09 PM   #7
Sal
Sal's Avatar
With a name like "Sal", you KNOW that I recommend olive oil.
Put a drop or two on the offending spot. Let it sit a minute or two, then rub it away.
Sal is offline   Reply With Quote
The Following 2 Users Say Thank You to Sal For This Useful Post:
Airedale1 (11-20-2014), Slickcraft (11-14-2014)
Old 11-14-2014, 11:32 PM   #8
tummyman
Use a little butter....rub it on and the pitch will come right off. Great when you get pitch on your hands, etc. Just a little butter and it is gone.
Old 11-15-2014, 02:16 PM   #9
ghfromaltonbay
Default Vegetable oil
Any type of vegetable oil (corn, canola, etc.) also works, and with the price of butter lately, a cheaper alternative.
Old 11-15-2014, 05:52 PM   #10
glennsteely
glennsteely's Avatar
Thumbs up All good advice.....somewhat.
I was in the car detail business for years, and automotive finishes are somewhat touchy, all of those suggestions will work, but i cant promise good end results, after strong sun, salt and acid rain have their way with the finish after treating them with those things......several manufacturers Make automotive clay, this clay is re-usable and i would suggest everyone own a hunk. You simply use a bug and tar remover, made for auto finishes with this clay to pick up anything on the surface of the car, without harming the finish.......just a suggestion.
You have to go out on a limb sometimes, cause that is where the fruit is. You can't get to the fruit from that nice safe spot, clinging to the trunk of the tree......
glennsteely is offline   Reply With Quote
The Following 2 Users Say Thank You to glennsteely For This Useful Post:
Den65 (11-17-2014), Descant (11-15-2014)
Old 11-15-2014, 07:48 PM   #11
Greene's Basin Girl
Thanks everyone for your ideas! I will let you know if the itch comes off after I try some of these products.
Old 11-17-2014, 03:43 PM   #12
Itch?Thats a lot different than pitch.First put some cream......
rander7823 (11-17-2014)
Old 11-17-2014, 05:53 PM   #13
glennsteely
Thumbs up Hahahaha!!
Hehehehe!!! Siksukr strikes again......too funny!!
The Following User Says Thank You to glennsteely For This Useful Post:
BroadHopper (11-18-2014)
Old 11-18-2014, 08:02 AM   #14
Keep in mind unless you use something wax based already think like your also removing whatever protection (wax) you may of already had on the car. Might want to have some wax handy and just hit that spot when your finished. Personal preference I like keeping my car waxed others are like "wax what's that??"
Old 11-18-2014, 04:45 PM   #15
I thought you were going to invite us to a pitch party....
Old 11-18-2014, 04:55 PM   #16
gasoline works awesome
just re-wax that little spot after
also works awesome on road tar
Old 11-20-2014, 02:47 PM   #17
Smith Point
Electric shave! That’s all you need to know.
Smith Point is offline   Reply With Quote
This page was generated in 0.34862 seconds
