Old 08-20-2014, 09:31 PM   #1
Default Pellet stove installation
Just purchased a pettlet stove insert on Craigslist. Stove is basically brand new, only had a few bags of pellets burned in it ! Owner was concerned that outside of stove heated up too much, and he has 2 little toddlers and was very concerned for their safety. His loss my gain !
Anyway need to have stove installed into an existing brick, clay lined fireplace.
Getting estimates for installation now by stove/chimney companies.
Question to the Forum...... Does the stove pipe chimney liner need to be 'stainless' steel? I thought pellet stove venting did not require this, but only needed to be aluminum or galvanized material?
The liner will be roughly 25-30' from fireplace hearth, up through damper, to the top of chimney.
If I have to install 'stainless' steel it will be costly compared to aluminum type.
Your comments are much appreciated !
Bigdog
Old 08-20-2014, 09:41 PM   #2
Bigdog
Bigdog...do yourself a favor and head over to hearth.com and join the forum called the Pellet Mill. Tremendous resources there. I have been a member for 5 years and have owned 2 Harman Stoves over the course of 18 years.
BT
bigdog (08-21-2014)
This page was generated in 0.06842 seconds
