Have a issue with a kitchen faucet.
It's a Delta faucet.... I am replacing the tiny springs and rubber bushings under each faucet handle. I've replaced one already but having an issue removing the handle from the other. The handle (L type handel) is held to the post by a 'tiny' Allen screw. I am using correct allen wrentch, but the screw appears to be mostly stripped in the handle hole from a previous replacement I suspect? The screw is located under handle L without much clearance, just enough for me to place the allen wrentch. About the screw possibly being stripped or partially stripped..... Any suggestions on how to remove? I'm at a loss at this point. Thanks for any suggestions ! Bigdog |
| The Following User Says Thank You to bigdog For This Useful Post: | ||
Not to Worry (08-07-2014) | ||
Call delta. They have great support!
The hex where the wrench goes is probably stripped. Try a small flat bladed screwdriver. Sometimes you can catch the corners of the hex with the tip of the screwdriver.
If what Rusty suggested does not work, You may need to remove the whole faucet from the sink to get better access. If the hex socket is stripped, the only think that will work is to carefully drill it out. Be careful not to remove the threads. just use a drill that is slightly smaller than the internal diameter of the threaded hole. Hopefully, Rusty's trick will do the job as it is a simple solution.
Good luck! R2B |
Go to Home Depot or your local hardware store and buy one of these.There are different types but here is one.
SIKSUKR |
Try filing down the top of the Allen wrench. This will square off the profile of the wrench, and the bite will be optimized. Use as much pressure as you are able when you press the wrench on to the set screw. This is your last shot before getting out the drill.....
