Old 07-20-2014, 08:43 AM   #1
Monarch Vu
Default Water Level
New to Lake and have our boat in Parker Marine. Lake is so high we barely fit under bridge. According to the state charts the water is above normal height. Will the state increase outflow?
Monarch Vu is offline   Reply With Quote
Old 07-20-2014, 08:49 AM   #2
pjard
We went by the lake level marker yesterday at Weirs Beach and it was about an inch below full lake.
Old 07-20-2014, 09:03 AM   #3
Lake level is in a normal range, they might increase outflow a little but that will not have much of an impact.
http://www2.des.state.nh.us/RTi_Home...+Winnipesaukee
http://www.bizer.com/bztnews.htm#lakelevel
As the historical data shows docking at Parker could be a problem most anytime of the year.
Old 07-20-2014, 11:07 AM   #4
Default Not their marker?
I spoke to someone from Wetlands in Concord last year and he claimed that he didn't know there was a level marker under the Weirs Bridge. At the time the marker showed about 2 inches below "full Lake" and the person I spoke to said that we were at "full lake".
So, although it is an indicator, I am not sure how that marker corresponds with what the people at the state level are thinking.
I also suggested that they increase the outflow at night and slow it down during the day to decrease the current in the Weirs Channel while people are navigating through there. It is my feeling that it is a safety issue. He said that was not possible since they don't work nights so it has to remain where the leave it when they go home.
Last year the substantial current in the channel did not slow until mid July. This year it has not been nearly as bad.
Monarch Vu (07-20-2014), soupyjr8 (07-20-2014)
Old 07-20-2014, 12:00 PM   #5
Resident 2B
Resident 2B's Avatar
So they cannot raise it in the morning when they arrive for work and lower it in the evening when they go home? I do not understand why that is impossible.
R2B
Old 07-20-2014, 01:50 PM   #6
R2B
That is because you are not a state "worker". It must be on a "need to know" basis and people like us don't need to know!
secondcurve (07-20-2014)
Old 07-20-2014, 02:36 PM   #7
RLW
RLW's Avatar
Smile
Monarch Vu , I just noticed that you are fairly new to posting on the forum after joining back in August 2013. We are glad that you have come aboard and joined us. Have fun and enjoy the Winni Forum while making many new friends.
Thanks for logging in on the forum and speaking up. Enjoy and come on back more often.
Old 07-20-2014, 10:21 PM   #8
jeffk
jeffk's Avatar
The management of the water level is more of an art than a science. The amount of water that flows into the lake depends on a lot of factors that cannot be accurately measured, only guesstimated. When there is a heavy rainfall and several inches of rain enter the lake, it can take 3 or 4, 24 hour days to drain the lake back down. If you drop the rate during the day that could now take 5 or 6 days. Suppose there is another rainstorm in that time? Now too much water is in the lake and you have to take extreme measures to get rid of it.
Further, the amount of water that can be drained is limited by downstream concerns. It's not just Winni that is being managed.
Most of the time, people want a bit less than a full lake to limit erosion and other high water damage. But not too low to cause rock clearance and shallow area problems. These concerns can be in conflict with access through some other areas because of water on the high side of normal. You are not going to make everyone happy.
I think the best you will get is that it is somewhat predictable. I think the dam operators have done a pretty good job over the last couple years keeping things within expected parameters. Except .... the last few weeks has seen the level rising and the dam NOT increasing output. That seems like a goof up.
Old 07-21-2014, 08:46 AM   #9
Lakegeezer
Default Thoughts for a Monday morning
When the level is full, or above, erosion is going to occur, especially with the multi-foot level wake that comes on weekends. The frequency, wave height and intensity of wake is scouring shoreline much more than it was 50 years ago, or eons before that. This, along with many other things, is accelerating a millennial of lake aging into a century or two.
While I agree that the dam operation staff has done well over the past few years, it would be nice to see more transparency into their decisions. For example, why does the lake discharge report show a 99% drop in flow (4-5 cfs) for two days starting July 11'th? Is it valid data or instrumentation failure? Why is the discharge rate today at 600 cfs, when the lake is at the top range of normal? A weekly blog from the dam operations staff would be appreciated.
Some have proposed that boat wake is no worse for the lake than a good windstorm. Perhaps on the lee side of the broads, this is true. For the narrow sections of the lake, it is not. Nature (other than human nature) never hits the shoreline in the same way.
Don't get me wrong. Winnipesaukee is still a very clean lake when compared to others. But the mechanisms that cause increased aging are easy to find. Government (fed, state, local) action can help reduce "cultural aging", but those methods are not popular or as effective as everyone doing their part.
Our responsibility, as stewards of the lake, is to become better educated on the issues and causes of reduced quality, then take steps to reduce our contributions to the lake's aging.
We can start by reducing the speed and volume of water running off our properties. Remove pet's waste. Don't use phosphorus based fertilizer on our lawns. Greatly reduce use of insecticides, such as diazinon (for ants) and pyrithrines (for mosquitoes) - as a very small amount will wipe out microscopic algae eating creatures. Maintain septic systems. Help to educate others.
We all contribute to the lake aging faster. The lake can absorb some human activity, but not an infinite amount. The first steps to a cure is awareness and stewardship.
The point of all this is, while we should all do our part, the state controls the dam - which along with weekend boat traffic - is also a major contributor to lake aging.
-lg
The Following 2 Users Say Thank You to Lakegeezer For This Useful Post:
Greene's Basin Girl (07-21-2014), LFOD (07-22-2014)
Old 07-21-2014, 03:59 PM   #10
NH_boater
Parker. Fit under OK. Lake rises. Can't fit under. Parker not friendly or accommodating IMO.
No more Parker for me.
NH_boater is offline   Reply With Quote
Old 07-21-2014, 10:41 PM   #11
Default Lake Level Marker
To the post about the Wetlands folks not knowing about the lake level marker: DES is a busy place with several divisions. The wetlands folks really don't have much to do in this area. The Dam Bureau is the place that controls the 300 or so dams that the state owns. There are also many owned by private parties, Village Districts, etc. that they inspect/monitor.
In addition to fitting under bridges, there are concerns about low water at the end of the season and being able to use docks when lake levels are low. They used to consider Labor Day as end of season and start lowering water accordingly. In the last decade, they have been more looking at Columbus Day as the end of season and that has resulted in a much better situation for those with shallow water docks.
Old 07-23-2014, 04:52 PM   #12
Farfrumbehavin
If the lake is 71 sq miles and you tried to drop the level 1in, you need to dump 139,029,844 gals of water. If you let 600 cu ft/sec through the damm you would dump 16,156.800 gals in a 1hr period. So you would drop the lake more than 1 in overnight if you released 600 cu ft/sec and no other water was entering the lake from brooks, rivers, springs etc..... so if you release 600 cu ft per/sec for a 24 hr period and the level stayed the same then you will know how much water is entering the lake per hr. Of course we would have to make some adjustment for evaroration, water that is removed from the lake on bathing suits, ducks feet and such. Problem is the conditions are changing constantly so as soon as you think you have it all figured out it starts raining or it cools off and you gotta start figuring out the eqaution all over again. The solution might be to have DES run three shifts so they can pass accumulated data on the the next shift coming into work. Then it gets real dificult because one land owner wants the level higher and one wnts it lower proving that you just can't keep evry one happy. I vote for leaving things the way they are, and think that the people who are in charge of controlling the lake level do an incredible job. I would suggest giving them a raise but that would raise boat reg fees and even more people would complain! WOW my brain is tired, I need to go sit down and cool off.
Farfrumbehavin is offline   Reply With Quote
This page was generated in 0.15925 seconds
