Old 08-29-2013, 05:46 PM   #1
Scuppers
Default cost of new seasonal dock?
Hi
Does anyone had a ballpark figure for what I should expect to pay for a seasonal dock(one that pivots up in the winter).
Thanks.
Scuppers is offline   Reply With Quote
Old 08-29-2013, 09:46 PM   #2
Bear Island South
Bear Island South's Avatar
If you are talking about an aluminum crank up dock you can expect $10-12K
Old 08-30-2013, 02:09 PM   #3
RobertsCove0
Default Seasonal Dock
6x30 - $8500
6x40 - $9500-10500
RobertsCove0 is offline   Reply With Quote
Old 08-30-2013, 03:14 PM   #4
Water Camper
Is a crank up dock considered a seasonal dock as it is permanently affixed to the shoreline ?
Thanks,
Bill
Old 08-30-2013, 03:28 PM   #5
sluggo
Water Camper... Yes the crank up dock is considered a seasonal dock because it is removed from the water each year. The permanent fixture of an anchor pad needs to permitted since it is an addition to the shoreline. Most of the time you will see a cement block as an anchor but in many cases the use of the original granite or glacier stone on the property is used to affix a custom steel header to attach the dock. This way a more natural application is achieved along with a nice clean look.
Old 08-30-2013, 04:42 PM   #6
Scuppers
Default Thanks
Thanks for the replies. That was pretty much where I thought it would be.
Old 08-30-2013, 05:27 PM   #7
tummyman
In Moultonborough, your property taxes will also increase, as the town taxes crank up docks. Assessments seem to be in the $9000 range. At the current tax rate, that is about another $75 + per year on property taxes. A small number, but they all add up.
Old 09-05-2013, 06:22 PM   #8
Are seasonal docks not supposed to be taxed because Meredith is hitting me on mine. I've peeked at my neighbor's assessment on either side they both have seasonal docks as well. One is being hit one not. So what's the story?
Old 09-05-2013, 09:45 PM   #9
tummyman
Seems it goes like this....
Permanent Dock...Taxed
Lift up dock....Taxed, as it is attached to the land all year.
Seasonal Dock that is totally removed from the water seasonally...not taxed as it does not add value to the land.
This is what I have seen.....
Bucktail (09-06-2013)
This page was generated in 0.07659 seconds
