Old 03-26-2013, 06:43 AM   #1
Lightbulb Hot Tub—for Islanders?
Just six years ago, this modern wood-fired hot tub would've set you back $7000.
However, today, they're made in China, and priced under $1000. For most of us, you can now get a cheap hot tub in-a-walk.
(Accessories include a wok).
Heating with wood is a great way to reduce our collective load on "the grid". The idea of a wood-burning hot tub isn't new—per this excerpt:
"...I have a wood-fired hot tub, so I live in the tub all winter and heat it by scrounging construction debris and like to visit the dumpster behind the Inn at Church Point....high standards....here!"
...and transport doesn't seem like a drudge:
The Following 2 Users Say Thank You to ApS For This Useful Post:
GsChinadoll (03-26-2013), WIS (03-26-2013)
Old 03-26-2013, 10:23 AM   #2
magicrobotmonkey
The burning question is where can you buy one?
magicrobotmonkey is offline   Reply With Quote
Old 03-26-2013, 11:58 AM   #3
Bear Islander
Bear Islander's Avatar
If you get the fire nice and hot can you cook lobsters?
The Following User Says Thank You to Bear Islander For This Useful Post:
Argie's Wife (03-27-2013)
Old 03-26-2013, 02:02 PM   #4
Happy Gourmand
Happy Gourmand's Avatar
Yes you can, just make sure their claws are banded so you don't get pinched. those little buggers are strong!!!
Old 03-26-2013, 03:19 PM   #5
Default In the original picture..
It looks like a commercial wok on the top of the fire. Anyone for shrimp fried rice????
Just saw that the wok is an included accessory. duh...read the article in full, Uppy.
Old 03-27-2013, 05:24 AM   #6
Smile Plant a garden. Heat with wood. And thank a veteran...
'Maximum capacity is 200 lobsters, but you must use coal instead of wood.
Good question. I think www.alibaba.com is a wholesaler—if you need a coupla-hundred hot tubs...
• This may get you to a retailer; however, there may be more than one design—with different pricings:
http://alfitrade.com/alfibrand/firehottub/.
Sears doesn't carry it.
• Retailers claim it takes two hours to reach 100°-F, but they don't specify using Winnipesaukee water! (A big advantage if only used on weekends—no water maintenance—just fill and fire.)
• Here's the thermosiphoning principle:
• And yes, you can take a wood-fired hot tub with you :
Old 03-27-2013, 08:46 AM   #7
Flyfisha
Funny the website quotes $3999 where do you get one for $1000?
Old 03-27-2013, 12:25 PM   #8
Argie's Wife
Argie's Wife's Avatar
Talking
There's a $20 version of this you know...
Feed 10 guys spicy chili, wait an hour, and let them sit in a regular swimming pool. Same results.
Old 04-04-2013, 05:32 AM   #9
Post ...following-up...
I've managed to find the original $1000 site—the minimum order from China turns out to be 1.
As China is about to become the world's largest English-speaking country, I'm awaiting a few [language] clarifications from their website.
Available in at least four colors, it's not clear whether the tub is also available in black—my pre-heated preference for a sunny location—or if a spare heating coil can be ordered separately. I'd like to build one out of materials already on-site.
Suggested colors:
In analyzing this further, it appears to be 62" (1600mm) across. OK for two adults.
Lightweight, it appears you can borrow one from a neighbor!
As I appreciate "low-tech"—and to increase the utility of materials already on-site—I think I'm going with the wood-fired FLL™ model:
This page was generated in 0.11853 seconds
