12-22-2012, 07:51 PM | #1 |
Water Hammer Arrestors..Washing Machine)
I just bought a NEW pair (Clothes Washer/Dryer) High end LG.
I'm Having a Mild banging .."water hammer": I have looked at commercial "Water Hammer Suppressors" ... I am considering building my own......SOLDERING IT UP WITH COPPER Tube and FITTINGS....an AIR CHAMBER. The fitting coming directly out of the washer is CPVC. It's a pretty strong plastic.....BUT I am a little hesitent to HANG the comercial supressor on it....cantalever (bending) stress. Any advice here...?? NB |
12-22-2012, 08:52 PM | #2 |
I installed these on my hot and cold water shutoff valves for my washing machine. @ $13 each at Home Depot:
http://www.homedepot.com/webapp/wcs/...ct_description . . . . .
The Following User Says Thank You to Rusty For This Useful Post: | ||
Slickcraft (12-23-2012) |
12-23-2012, 04:02 AM | #3 |
A professional plumber installed these long copper "detours"—shock absorbers that trap air to silence the problem.
The cost to a home-handyman-plumber? ...about $2. To me, this file-photo shows very generous lengths but it will depend on the length of your "run" to the washer. Elsewhere, I've done the same installation with PVC without any issues: especially in a cottage with seasonal use, either type should work just fine. |
12-23-2012, 11:43 AM | #4 |
Rusty: That Oatey suppressor is Exactly the one I'm looking at if I don't build my own. Home Depot around here is sold out..OR doesn't carry that brand. My local hardware store has them for $21.99..same model number. I like the quality better than the other similar brands that Home Depot has on the shelf.
APS: That's pretty much what I am considering doing. The store bought model is easier though. NB |
12-23-2012, 11:56 AM | #5 | |
The problem with the one that APS posted is that they lose air and you have to drain them every once in a while. Also with the price of copper these days it would probably cost you as much. The Oatey suppressor has a plunger in them at the top and air can't escape. Good luck with whatever you do.
12-23-2012, 05:27 PM | #6 | |
12-23-2012, 07:16 PM | #7 |
Try EBay....search for Oatey 38600. One is one there for $13 plus 3.50 shipping to your door. Amazon (search for the same item) has them for $16.98 with free shipping and no gas costs to drive to Home Depot, etc. Surely you can wait for the delivery.....
01-08-2013, 09:10 PM | #8 |
This is what I did. Home grown. It's working. No more Water Hammer bangs. The original supply tubing is 1/2 inch. The "Chamber" is 12 inches of 3/4 inch tube with a cap on top and an elbow to connect it to the original tube. The washing machine and dryer are on the OTHER side of the insulated wall. The Hoses to the machine drop off the bottom of the faucets,
01-08-2013, 09:49 PM | #9 |
The "Oatey" supressors that Rusty suggested are much smaller. They have a piston inside that allows them to be positioned at ANY angle. My "Chambers" must be oriented Vertically to preserve the Air BUBBLE in the top of the chamber. NB
PS: I would NOT recommend the procedure I took to anyone.. who is not TOTALLY confident in their skill in soldering wet tubing. |
01-09-2013, 04:02 AM | #10 | |
"Old-Tech" is Better...
—> Soldering in cold and windy locations doesn't warm you up! The gauge in the photo reminded me that I could have put an el-cheapo water pressure gauge at the top of one of those chambers. In a search related to your original post, it was apparent that suppressors weren't consistent in fixing the problem, and required an occasional return to the store! |
02-02-2013, 10:58 AM | #11 | |
Moose Tracks |
02-03-2013, 03:02 PM | #12 |
When I redid part of my home plumbing, I made some short uprights on T-fittings. They are installed on the horizontal runs. I have not had any problems and the practice in making these things up, came in handy too.
Good luck! |
02-03-2013, 06:34 PM | #13 | |
I guess you had fun doing it so not all was lost.
02-03-2013, 06:50 PM | #14 |
So far so good and if it hammers again I can drain hot and cold from the laundry tap but thanks for the heads up. These pieces were almost fun but the up and down combo joints at the end of the line for the shower and laundry cut-offs were more challenging.
02-03-2013, 07:57 PM | #15 |
Before I put in the two 12" do it myself air chambers..I had had an Oatey suppressor on the right (Cold) side ..oriented vertically.
After I replaced the Oatey Suppressor with my own vertical PAIR of air chambers ..On the Bench: I cut the OLD Oatey suppressor apart to see what was inside. There was a little plastic free ranging piston with two "O" Rings. The Piston was at the TOP of the cylinder.....which indicated to me that the AIR above the piston was gone. The hammer damper was dead. The Oatey suppressor had been oriented Vertical. I realy like the LG washer and dryer. They are almost silent..compared to the old machines. I Can't hear them running. There is a little "RingTone" that announces when the cycle is done....NB |
03-04-2016, 07:55 PM | #16 |
Update
I have been using my home made vertical tube suppressors ..previously pictured above. They Work: HOWEVER: They need to be drained every three months or so..depending on the frequency of use of the washing machine. Shut off the water main and draining takes about 15 minutes.
I'm now looking at commercially built "Mini Trols". They have a rubber diaphragm that separates the water from the air. I haven't done the change out yet because the "Mini Trols" are about 1/16 inch TOO big in diameter to fit where the old vertical tubes are. Need to do un soldering and then re soldering of the cross connectors and elbows. Soldering wet pipes is A PITA. NB Mini Trol suppressors: http://www.amazon.com/Amtrol-Mini-Tr...mer+supressors I have found them locally for less than $50. |
03-06-2016, 08:26 AM | #17 |
If your only problem with your home-made device is the time to drain your system, I suggest that you add shut-off valves just upstream from them. Close the new valves and open the faucets. The process shouldn't take more than 5 minutes. Good luck! |
